Question about Nokia C5 Cell Phone
Nokia c5 wont deactivate offline then says insert sim
Wont deactivate offline
  • Nokia Master
  • 14,641 Answers
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Posted on Oct 25, 2012
SOURCE: Changed nokia e66 housing.. and now offline
I have the same problem..i replaced the sim band and the problem still persist.. what to do ? :' and my wifi dont detect any network :' wtf?:((
Posted on Oct 15, 2010
zaids
  • 456 Answers
SOURCE: Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Posted on Sep 29, 2008
fossildude
  • 832 Answers
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
Posted on Jun 15, 2009
jan mczeal
  • 632 Answers
SOURCE: my phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
Posted on Jul 16, 2009
raingamj
  • 2148 Answers
SOURCE: my nokia n73 seems offline and say insert sim even
After you have inserted the sim card messages shows"start up phone without sim".Yes Or NO, press NO. If not OK the problem comes from sim IC or Sim case.
Posted on Aug 11, 2010
My nokia c5 is in offline mode.icannot teceived text and calls.how can i change my mode to online
Make sure your phone is not in Airplane / Flight mode. Go to Settings > Profile. Select Normal.
If your phone still stays in offline mode, it is possible there is a problem with your SIM card. Turn off your phone; remove the SIM card; reinsert the SIM card; turn on the phone.
If the problem still persists visit your mobile phone store.
Feb 04, 2015 | Nokia C5 Cell Phone
Nokia c5 offline mod problem
If you have activated the General profile/if you have inserted other sim card and even there is no effect, it means that the sim card is not detected to your phone.So,to solve this problem you need to visit mobile repairing shop.There might be damage/ something wrong in the Sim card related components.Good luck
Oct 12, 2011 | Nokia C5 Cell Phone
NOkia C5 in offline mode. how to deactivate offline mode. Tried changing the profile.. but it says "Insert SIM"
if you hold finger on the volume up button dial a box comes up on the bottom of the screen says do you want to stay offline you press no and the phone will reboots itself into normal mode
Aug 14, 2011 | Nokia C5 Cell Phone
How to make the nokia c5 phone from offline to online
My dear,
Just select settings, profile select the offline mode and it will be activated.
Or, you can switch off the phone, remove the sim card and switch on, it will ask "use phone in offline mode" click yes and phone eill be on in offline mode. When you insert sim card it will still ask the same question select any of your mind and enjoy your phone
Jun 08, 2011 | Nokia C5 Cell Phone
Dear my friend I have a NOKIA C5. I have offline problem. I turned off the mobile set but it did not being solved. It would be appreciated if you kindly help me. Best regards Omid
Your phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Mar 31, 2011 | Nokia C5 Cell Phone
My n70 is going offline offline mode i m trying to change profile in general mode but it say insert sim card what do i do...
someone or you might have coded that phone with a line different from the current line so you must deactivate that code by inserting the formal line.or if you dont know the code you have to flash the phone.
Mar 14, 2011 | Nokia N70 Cellular Phone
Offline Mode
menu>setting>profile>SELECT GENERAL OR SILENT as you wish
Jul 11, 2010 | Nokia E66 Smartphone
My phone nokia 6680 has been in the offline mode.i want remove it
Jul 16, 2009 | Nokia 6680 Cellular Phone
Nokia C5 Cell Phone Logo
164 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
