Question about Toshiba Camileo X416 16GB HD Flash Memory Camcorder Black
How to adjust volume on a Toshiba Camileo X416 full HD 1920x1080
When videoing and playing back you can't hear the voices. Where can you adjust the volume?
4 Suggested Answers
  • 102366 Answers
SOURCE: ny Toshiba Camileo P10 is reading "card locked"
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Feb 19, 2011
Testimonial: "thank you ! Obvious really once you know....but I did't....many thanks AS"
hmerchant110
  • 7191 Answers
SOURCE: How can i get a
You can view, download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this solves your problem. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on May 03, 2011
  • 13 Answers
SOURCE: How to download a video to facebook from toshiba
Look Around the power switch or the bottom for a USB port.
Posted on Jul 04, 2011
Getting my camileo X200 videos to play on my computer
I personally use VLC, it'll play just about anything you throw at it. You can download VLC Player here: http://www.videolan.org/vlc/
There is also a codec that comes preloaded on the device, but I would recommend VLC.
Dec 27, 2012 | Toshiba Camileo X200 Camcorder
What camcorder would be suitable for producing wedding videos?
Canon HV40 is a good option but only as a backup option for your main paid and good gigs you can take a DVX100B. The Toshiba Camileo S20 offers Full HD 1080p video recordings and is your cheapest option to HD. I'd say that a decent Sony or Panasonic camera is your next option if you're looking for Wedding Cinematography even better performance. They have many HD cameras. But the actual concept is the budget and you can look up all this in the net and have very nice offers doing it.
Dec 27, 2012 | Cameras
Does anyone have low volume during playback on the toshiba camileo x100?
you can make the audio louder. see about raising the volume and then when playback make sure it's not too loud. If that doesn't work then the cameras is set low in the audio. see manufacturer if they have a solution. or in the camera see if there is a volume control, maybe it's set low.
Sep 07, 2012 | Toshiba Camileo Video Cameras
My Toshiba Camileo x100 won't charge?
Try with normal USB cable &take out laptop USB port .actually I misplaced my ac adapter try for many solutions at I found this
Jul 02, 2012 | Toshiba Camileo X100 High Definition...
Camileo s30 not charging
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Mar 15, 2012 | Toshiba Camileo S30 HD Camcorder -...
Will my virgin hd tv remot control be able to oporate the volume through its own amp or will i need to adust the volume with the toshiba tv remote on the tv itself
The easiest way is just to set the TV Volume with its own remote at the maximum level you'd want it and then use your Virgin remote to adjust the volume as and when required.
Jun 05, 2011 | Toshiba Televison & Video
My built in mic is not working properly,when I call somebody hear me but I don't hear him!
If the other person can hear you then YOUR microphone is working fine.
The reason may be that his microphone is faulty (solution below)
Otherwise:
  1. Make sure the volume is turned up on your speakers (and if using external speakers they are plugged in / turned on) . To increase volume go to Control Panel, Sounds & Audio Devices and adjust the slider on "Device Volume" . Also click on "Loudspeaker Volume" and adjust the sliders there as necessary.
  2. Can you hear other sounds (like playing music or videos)? If yes then you need to adjust the audio settings for your calling program (skype or whatever). Launch the appropriate program Click on Tools and ' test audio properties' on the program tool-bar. Follow the instructions on the screen.
  3. Try plugging in headphones and see if you can hear better on them.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
Feb 09, 2011 | Toshiba (P000257700) Microphone
My Ipad volume is way too low when playing movies. Can you help?
Try adjust the control panel to full volume. If it the volume is still too low to hear movie conversation, put the movie back to computer and use some video tool to set it volume up. I think the pavtube video converter can increase video volume by 400% by converting them.
Oct 11, 2010 | Apple iPad (16 GB) WiFi Tablet PC
I'm on Skype, and the person I'm talking to cannot hear me. They can hear feedback sounds from their computer and their voice, but can't hear me talk. This a Toshiba with a built in video camera and...
The problem seems to be with your friend's setup, and possibly yours. Try adjusting mic levels and volume levels to where they don't interfere with each other. Ex.--you talk , they hear you at a volume that is too loud and it gets into their mic, creating a loop....feedback. You do the same too. Trial and error. Hope this is helpful.
Apr 23, 2010 | Toshiba (P000257700) Microphone
Toshiba Camileo X416 16GB HD Flash Memory Camcorder Black Logo
37 people viewed this question
Top Toshiba Video Cameras Experts
Voros101
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
