Question about Kodak EASYSHARE CD33 & Printer Dock Series 3 (Pack) Digital Camera
I took my ink cartridges out to replace them and let my top down now my ink cartridge want release help
    Genius:
  • Kodak Master
  • 1,019 Answers
What make and model printer are we talking about ?
Posted on Jan 24, 2013
Replaced ink cartridges but still get note to change cartridgees.
Pull the ink cartridge hook toward you and remove the ink cartridge for the colour shown on the LCD. Reinstall the ink cartridge and press down on the ink cartridge until the hook snaps over it securely. Push the hook towards the cartridge to verify it is securely latched over the top edge of the cartridge.
Keep the ink cartridge in an upright position when you insert it into the slot. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge.
Jun 29, 2010 | Brother MFC 420CN All-In-One InkJet...
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
U163 keeps coming up!!
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. Confirm that the printer is powered on
  2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
Note: After confirming that the scanning unit support is fixed into position, release your hands.
3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
Note: - Do not attempt to reattach the protective tape once you have removed it.
- Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot**One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
8. Confirm that the ink cartridges are installed properly.
<1> The ink cartridge is not installed properly.
<2> The ink cartridge is installed properly.
  1. Fold the scanning unit support and close the scanning unit (printer cover).
  2. Wait until the preparatory operation is complete; it takes about one to two minutes.
I hoe it helps!!!
Dec 05, 2008 | Canon PIXMA MX310 All-In-One Printer
Epson 2200 ink replacement light stays on
I had the same problem with the light black and light magenta as well. It took trying only one new cartridge with the light magenta before it worked.
The light black took 4 new cartridges before it worked. I had called the Epson support center on this problem and after going through suggestions they made that did not work, I told the guy I had another new cartridge on hand. He said to go ahead and try it. This time the printer worked. He took my name and address and said the other cartridges were faulty. Epson is sending me new replacement cartridges at no charge.
Dec 04, 2008 | Epson Stylus 2200 InkJet Photo Printer
My HP photosmart C4200 ALL-in-One series is telling me is telling me that my print cartridge is missing or not detected, I just barely replaced the ink.
Below is a partial entry of the help document at HP. The complete text can be found by clicking on this link here.
If you have already read and completed these steps, please notify me that you have by using the Text Area Comment Box below. Proivde me with any thing else you have already tried. Lastly, do you have a manual for your printer in digital format that you can place on your PC and refer to? I can post one here for you if you need it.
Essentially, there is no easy Trick to clearing this issue. The most common error made by users it in replacing both cartridges at the same time. Each cartridge should be replaced individually. Once completed the printer will want to execute a print head alignment test. This print out will include instructions on selecting the numbered lines that line up most exactly. Then you would enter the corresponding number.
Bypassing or interrupting this alignment test after replacing cartridges will cause error messages such as yours. So, if you did this out of ignorance or confusion, remove each cartridge one at a time using the method descrbed below. When both have been removed and reinstalled and the alignment process completed you should be error free. Should you still receive this error, remove and clean each cartridge using the method described below, one cartridge at a time.
If after completing all the steps below, you still receive the error message, your printer has a larger problem that is internal hardware related. You can either replace the printer or have it serviced by HP. Most people opt to replace the printer as an error such as this at the internal hardware level usually indicates that the printer has reached the end of its usable life span. If this is happening prematurely, have it serviced under warranty. Printer warranties are usually one year from HP. If you purchased using a credit card you may have an extended warranty. Check with your card company right away for information on any extended warranty you have from using your Credit Card.
If you have any further questions, please ask me using the comment box below.
Regards,
Worldvet
Solution one: Remove and reinsert the ink cartridges
  1. Turn the product on.
  2. Make sure to have letter or A4 unused, plain, white paper loaded in the input tray.
  3. Open the ink cartridge door.
    NOTE: Make sure that the carriage holding the ink cartridge moves to the right. If it does not move to the right, turn the product off. If it is a new product, make sure all the packaging material is removed. Close the ink cartridge door and then turn the product on again. The carriage should move to the right. Figure 1: Opening the ink cartridge door c01333689.jpg CAUTION: The product must be turned on before the ink cartridge door is opened. If the product is off when the ink cartridge door is opened for access to the ink cartridges, the product will not release the cartridges. The product can be damaged if the ink cartridges are not docked safely before removal.
  4. Wait until the carriage is idle and silent, and then lightly press down on an ink cartridge to release it. The error message should indicate the problem cartridge by displaying an icon that represents it.
    • The tri-color ink cartridge is in the slot on the left.
    • The black or photo ink cartridge is in the slot on the right.
    Figure 2: Pressing down on an ink cartridge to release it c01333690.jpg 1 - Ink cartridge slot for the tri-color print cartridge 2 - Ink cartridge slot for the black and photo ink cartridges
  5. Pull the ink cartridge toward you out of its slot.
  6. Make sure the tape has been removed from the cartridge. If the tape has not been removed, remove it now. Figure 3: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or reattach the tape.
  7. Hold the cartridge with the HP logo on top.
  8. Reinsert the ink cartridge into its slot by gently pushing the upper part of the ink cartridge forward until it clicks into the socket. CAUTION: When installing the ink cartridge, do not rest your hand on top of the product for leverage. This might cause the carriage to lift out of position. Figure 4: Incorrectly grasping the top of the product for leverage c01333691.jpg Figure 5: Pushing the cartridge in firmly c00853118.jpg
    • When installing the tri-color ink cartridge, slide it into the left slot.
    • When installing a black, photo, or gray photo ink cartridge, slide it into the right slot.
    Figure 6: Tri-color cartridge in the left cartridge slot and black cartridge in the right cartridge slot c00880896.jpg
  9. Close the ink cartridge door.
If the error message persists, continue to the next solution.
Nov 11, 2008 | HP Office Equipment & Supplies
How do i change the ink cartridge on my epson cx6400?
I am assuming that you already have a replacement ink cartridge.
  • Make sure the printer is on.
  • If the LCD screen says that your ink cartridge is empty than
you can simply press the Color button (the button looks sorta like a diamond with a line in the middle of it).
  • If you wanna change the ink cartridge but the printer does not say that it is empty then
press the setup button, then press the top left button until Replace ink is displayed. Finally, press the Color button.
  • Lift up the scanner section
  • Wait for ink cartridge holder to move to replacement position then open its cover.
  • Identify which cartridge you want to replace. Press in the tab to release the cartridge, then lift straight out.
  • Before unwrapping the new cartridge, shake it gently four times. Then remove from wrapper.
  • Lower new cartridge into holder, press down firmly until clicks.
  • Close cartridge cover
  • Carefully lower the scanner section and press it down until it clicks
These instructions were found in http://files.support.epson.com/pdf/cx64__/cx64__pg.pdf on pg 12.
Oct 12, 2008 | Epson Stylus CX6400 All-In-One InkJet...
CANT FAX
    *Optional cartridges PG-40 and CL-41 shown in examples
  9. Fold the scanning unit support and close the scanning unit (printer cover).
  10. Wait until the preparatory operation is complete; it takes about one to two minutes.
Mar 28, 2008 | Canon MX300 Office All-In-One Printer
Scanner
Solution: Replace ink cartridge(s) MX310.
Feb 08, 2008 | Canon MX300 Office All-In-One Printer
Hp psc 750 xi how to replace black ink cartridge
1) Pull out your old black ink cartridge, py pressing the button on top of the old cartridge and pulling it down.It will be released, then just get it out.
2) Look at the back of your new ink cartridge, there should be a small panel with some small squares and kinda orange panel, this is the side that should not face you, it should face the ink cartridge holder on the printer.
Just put it in like that. Tell me if you have any problems.
Nov 17, 2007 | Sharp AL-1655CS Laser Printer
Install Ink Cartridge
Swith on the printer. Open the printer top cover. It is called flap. Now press upwards the cartridge's top end. and lift up that. now take the cartridge out. insert the new cartridge the same way took the cartridge out. put the cartridge layer down. Now close top cover.
Oct 24, 2007 | Lexmark X1240 All-In-One InkJet Printer
Cameras Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
