Question about Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel
F10 error code on Model # FEFL79GCA Frigidaire Stove
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Posted on Oct 26, 2012
5 Suggested Answers
reg501
  • 413 Answers
SOURCE: Frigidaire Stove model # 791FEFS66DS
F10 is a Runaway temperature issue.
There are three possible scenarios:
1. The temperature sensor has failed.
2. The electronic control has failed
OR
3. The connector between the temperature sensor and the electronic control has failed.
The connector can be troublesome. The first thing to do is eliminate this potential issue.
  • Remove the back panel.
  • Locate the temperature sensor plug
  • Cut the plug off the temperature sensor wires and the corresponding electronic control wires
  • Using ceramic wire nuts, secure each temperature sensor wire to the corresponding electronic control wire.
If you need further assistance, let me know
Regards;
reg501
The FixYa Team.....
Posted on Jun 21, 2008
  • 1314 Answers
SOURCE: f10 code
replace the oven probe in the oven its the gold looking piece sticking out inside the oven
Posted on Aug 22, 2008
localwonder
  • 6784 Answers
SOURCE: Frigidaire oven F10 error code
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Posted on Nov 26, 2009
  • 506 Answers
SOURCE: we have a f10 error code on our electric range
F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
Posted on Dec 15, 2009
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Mar 29, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
My frigidaire stove I have to umplugg it because keeps beeping f10 can' stop I push any bottom and keeps beeping
Hi Elizabeth! From what you have posted, your appliance is experiencing a high-temperature error code (F10). A high-temperature error indicates that your oven has reached too high of a temperature for too long of a time period. If unplugging your appliance does not prove to be successful, you would require a visit from a professional to check the temperature sensor and the electronic oven control (brains of your appliance behind the touch pad). If you have any other questions please comment so I can help!
Thanks,
Chris
Dec 18, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
Sep 23, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
F10
Hello,the F10 error code means "Runaway temperature"most likely the problem is bad Electronic oven Control ("clock/timer").it has to be replaced together with the overlay because it's glued to the clock.
Thanks
Jun 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 15, 2009 | Frigidaire 30 in. Electric Gallery Series...
What does F10 display on my stove mean? Frigidaire Model PGF355DS
my frigidaire oven keeps flashing f10 and turning off
Apr 02, 2009 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
148 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
