Question about GE JVM1840 Microwave Oven
F3 error code ge jvm1840 - GE JVM1840 Microwave Oven
SOURCE: have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Posted on Jan 14, 2009
  • 178 Answers
SOURCE: GE Sensor Microwave model JES1456wf001 error code F3....how do we
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
Posted on Sep 14, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: f3 error code ge microwave
No, unfortunately the membrane keypad is not available as a separate part on this model.
You would have to order the control panel frame, which comes with a new keypad already installed.
The part number is WB07X10883 and you can get it for $86.82 here.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Posted on Nov 25, 2009
Testimonial: "Great feedback. I will follow it to a tee. Thanks"
MicrowaveSvc
  • 9085 Answers
SOURCE: F3 error GE Spacemaker XL 1800: Model JVM1851CD.
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 06, 2010
espressonist
  • 1711 Answers
SOURCE: ge microwave jvm 1430 error code F3
F3 Key panel (touch pad) shorted This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Posted on Nov 04, 2010
Has a code F3.
f3 error code is for bad panel control and your panel control needs to be replace
Feb 01, 2014 | GE Advantium 120 Convection/Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The unit is beeping and has a code showing F3
Is it difficult to change a touch pad on my ge profile eterna spacemaker microwave. F3 Error, Bought it new in 2006. Touchpad Part No# WB07X10959 Twinsinger asked.
Feb 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave jvm 1430 error code F3
Jul 17, 2009 | GE JVM1430 Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Error code F3
On a GE, F3 means that you have a shorted pad on the keypad.
This is not too hard a job for a do-it-yourselfer, but if you'd like, we do this job for $39.95 plus parts nationwide.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at ourlisting here on FixYa: http://tinyurl.com/yzjozk
There is also a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back (privately if you wish) with more details if you need further help.
fWe're happy to help and we appreciate your thoughtful rating of our answer.
Dec 22, 2007 | GE JVM1840 Microwave Oven
GE JVM1840 Microwave Oven Logo
23 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
