Question about Apple Macbook Computers & Internet
Macbook beeps on startup - Macbook Apple Computers & Internet
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Congratulations. Anything else to add? Like maybe a problem?
Posted on Dec 26, 2013
Macbook Air keeps beeping three short beeps in a loop
I need more info on which model Macbook air you have. You can try to reset the smc and pram https://discussions.apple.com/docs/DOC-3604
but three beeps is often memory related
http://support.apple.com/kb/HT5860?viewlocale=en_US .
Depends on the model you have whether or not the RAM is removable.
Oct 11, 2013 | Apple MacBook Air
Macbook 13" beep alarm at start up
Three beeps on a MacBook indicates a problem with the RAM.
Feb 10, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
15.4-inch macbook pro A1286 turn on but wont start
  1. Verify startup process passes initial memory checks and POST (Power On Self-Test) with no beeping sounds or flashing sleep LED. Check video activity.
  2. Disconnect any peripherals and Ethernet cable.
  3. Reset SMC using the procedure for your computer.
  4. Reset PRAM by holding down Command-Option-P-R keys while restarting, until you hear the startup sound for the second time.
  5. Start up from known-good original system media or an up-to-date, bootable Mac OS X volume.
  6. Run Disk Utility or check Mac Resource Inspector (MRI) results to verify SMART status of the your hard drive.
Jul 31, 2012 | Apple Computers & Internet
My macbook won't start. how do I eject an audio CD?
You could be right. What to do is start it up and hold down the trakcpad button as soon as it starts up. Failing that try the F12 key or the eject key when starting it up, sometimes actually lifting the macbook up and pointing the DVD drive downwards i.e. using gravity to let the CD drop.
If the CD ejects and it isn't the problem causing the startup problems, what I would be tempted to do if the other troubleshooting solutions have not worked, if it still under warranty or if you have Applecare, contact apple and arrange to get it taken in for repair. Failing that take it to your local Apple Store and make an appointment at the genius bar, they usually are fairly good at diagnosing problems and solving them.
Jan 02, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My Macbook Air made "beep beep beep" sounds when I
3 x beeps means there is a problem with the memory, either it needs reseating, replacing or a problem with the slots on the logic board.
Kev.
Feb 17, 2011 | Apple MacBook Air
The bios on the machine hardware has failed to book.
You could try plugging in machine and ensure battery is charged.
Press and hold the power button for about 20 seconds.
also the other thing is to immediately after you press the power button.
hold these 4 keys at same time continuously - cmd, alt, P, R
hopefully machine will power up and down and up again if you keep holding them.
Please dont forget to vote this answer was helpful
Many thanks
How do I restore the startup chime on my MacBook Pro?
You could try using the startup sound preference pane located here: http://www.macupdate.com/app/mac/16425/startupsound.prefpane
Dec 04, 2010 | Apple MacBook Mac Notebook
My macbook pro OS 10.6.4 either freezes or crashes on startup. Crashed when trying to startup with Drive Genious 3, TechTool Pro 5, System Disk or Disk Warrior. Not sure what to do next. Tried holding ...
Restart your mac. As it's restarting/booting up, hold down the command, option, R and P keys simultaneously. As it's booting up and you're holding these keys, you should hear the startup chime, continue to hold the keys down, it will cycle and you'll hear the startup chimes again. Let it go thru this cycle 7 (seven) times before you let up on those keys. Once it's cycled 7 times, let it boot up normally.
If that doesn't work, then reinstall the original system software that came with the Macbook. You may have to reformat the hard disk and do a clean install.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
My macbook do not startup and I hear 3 beep sound. Before I receive at hardware test this error code: 4mem/9/40000000: 16505c
just remove the ram and clean it and fix it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
: My macbook stopped recognizing both my DVD and CD drives, help
try to reset the PRAM (Apple - alt -P - R) , and hit the alt key at startup to see if you can startup on a volume
Jan 31, 2009 | Apple MacBook Pro Laptop Computer with...
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
