Where can i get a flat base to fit onn tv
NEED A FLAT BASE TO FIT MODEL AO42ZID TV
  • 7 Answers
SOURCE: I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Posted on Dec 23, 2008
SOURCE: Remove Base from Toshiba Regz 42RV530U
I bought this LG flat TV at Circuit City last week. TV is okay, but I was trying to hook up my portable DVD player and I can not make it work. I can hear the sound that coming out from the DVD but theres no picture from the screen. I believe my connection is correct, because there is the color coding which is red, yellow and white which you just connect at the back of the TV and at the DVD player.
Can anyone help me to figure out the problem. thanks a lot
Posted on Jan 31, 2009
  • 11 Answers
SOURCE: Missing Power Cord, Stand Base, Owner's Manual for Element 15" TV
The manfacturer has information for you about this model when purchased from Circuit City: http://www.elementelectronics.com/support2.html
The distributor Element uses provides parts at http://www.encompassparts.com/
(you may have to have a legitimate repair center login in and get parts from them)
Posted on Mar 30, 2009
SOURCE: removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Posted on Oct 26, 2009
SOURCE: Removing the stand from a flat panel TV
None of these TVs have any problem removing the stand.
Stands for 32'' and larger TVs plug into the TV's body and are attached by 4 to 8 bolts that go through the cover, then through the plugged-in part of the stand and attach to the internal frame.
In most cases the bolts are 4 - one for each ray of the fork that goes into the TV.
Since bolts for the frame are metal bolts and bolts for the plastic back cover are usually wood-type screws (sharp on the top, wider thread) you can visually tell the one for the stand from the rest.
Look right above the stand for four, six or eight symettrically placed heads that are different from the ones you see on the corners.
Once you unscrew those the stand should feel more flexible and you can simply pull it back.
In order to do all that you have to have the TV laying on its face or back.
Watch out if it's heavy - you may need to support it towards the end of the operation. It's unlikely for it to get damaged if it falls down, but you still don't want to try your chances.
Giving it a little lift also helps unscrew the last bolts...otherwise all the force of the TV is pressing against it...and that makes it harder to unscrew.
Posted on Nov 07, 2009
How do you install the feet on the Model 32K3110W TV
To install the base, put the TV down on a clean flat surface covered with something soft to avoid scratching the TV's screen. Put the two base pieces into the slots on the bottom of the TV; they will only fit one way. Next secure the base with two screws for each leg. With the 32" TV, you need ST4x12 screws. This is shown in the Quick Setup Guide and is available from the Hisense product support page: http://hisense.com.au/single_support/32in-led-series-3-32k3110w/#product-manuals . See page 1 for the parts list and page 2 for a sketch of putting on the base.
I hope this helps.
Apr 29, 2016 | Televison & Video
Will the base stand for a 42" Gallevia fit a 37" Vizio tv
Probably not.........Most tv's these days have to have a specific type stand that will mount to a specific tv. The designers have went overboard in designing their own models which will not fit other brands
Sep 17, 2014 | Televison & Video
Want to take base stand blanking piece off to fit stand on Lg 32 inch flat screen tv
You haven't supplied the exact model, but with most LG blanking covers they are usuall removed by a levering a plastic clip at the side of the cover & then simply pulling the cover forward.
Dec 26, 2012 | Televison & Video
What type of screws are used to secure the TV to the base
Although the base is plastic the holes where screws go are normally always metal fixed thread like grub screws, most tv use similar fixtures to fit tv to base , I would pop along to a electrical store and try and look at the screws used to fix the tv that are on display and compate a few, then try buying a set of 1/4 inch pan head metal thread screws from DIY store
Dec 07, 2012 | Hitachi P50H401 50 in. Plasma HDTV
How do i remove the stand/base off a panasonic viera TX37LZD70 37" flat screen tv so I can wall mount it?
Place the TV on a flat bed preferably your mattress and look for the base mountings. The lock and base mount can be slid off and you can use a good wall mount that will support the weight to be fitted.
Please find the link below for help:
Wall mounting flat TV
Jan 07, 2011 | Panasonic Televison & Video
How to fit swival stand on model le32b554 32inch
There are 4 screws in the back at the bottom centre of the tv. Remove these and pull out the blanking plate. Next insert the base upright assembly into the tv and re screw in the 4 screws
Mar 07, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
