HP w2480h monitor just flashes red, green and blue
Monitor is 4 years old
3 Suggested Answers
  • 84 Answers
SOURCE: My Epson C48 printer has stopped working
http://files.support.epson.com/pdf/cx48__/cx48__qr.pdf
There is a whole section devoted to troubleshooting the different lights, and if they flash or not. Without more of a description from you I was unable to discover right away which error it was, but you should be able to find out no problem with this manual.
Posted on Apr 08, 2010
  • 286 Answers
SOURCE: my HP 2480h monitor flashes red, green and blue
I am not familiar with your particular monitor. However, on many monitors when the screen flashes like this, it's a "burn-in mode" that is used to test the monitor at the factory.
1. Your firmware in the monitor may have glitched. Try the solutions offered by the other people here and see if you can reset the unit. If those simple solutions don't work, try suggestions below.
2. You may have one or two stuck buttons (they may be stuck or shorted). Try taking the monitor apart and unplugging the button board. If the fault stops, then there is a problem on the button board (control board). In many cases, replacing one or more of the switches will fix the control board. You will need spare switches and a soldering iron. If you have an Ohm meter you can measure all the switches and replace those with low resistance. Note, you may have to correct the switches and then implement one of the other solutions presented here in the other comments.
3. The chip that receives the signals (on the main board) from the control buttons may have gone bad. If this is the case, the only way to repair it is to replace the board, which is likely not going to be cost effective even if HP did have spare parts.
4. It's possible that the capacitors on the power board are letting enough noise through to mess up the main board. If they look domed, vented or cracked, they should be replaced. You will need spare capacitors of the correct values (stamped on the side of the capacitors), a slodering iron, solder and perhaps some solder braid or a solder ******. If you do this yourself, make sure you install the new capacitors with the correct polarity or they can pop (there is usually a stripe down one side indicating negative, and a corresponding mark on the board).
Posted on Oct 25, 2012
Hp w2408h monitor flashing red green black blue white
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 10, 2014 | HP W2408H 24-inch Widescreen LCD Monitor
Hp monitor flashes solid colors
Hi there, the mode the unit is in is like self test. Try first to disconnect vga cable from pc and see if the there is notification "no signal" poping -up to see if the problem is not graphics. Anyway you can try to disconnect power cord from monitor and wait a while then try again power it on. If all this doesnt help it will be more then good advice to RMA it if still in warranty. Tnx
Sep 23, 2013 | Samsung Computers & Internet
I have a 24in wide lcd monitor for my computer and
mcdevito75 here, The red power light usually means the monitor is off, if when you press the red button it turns to green, or blue then the red power button means the monitor was off. Your monitor could be burned out.
Jul 16, 2010 | Computers & Internet
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Red color problem
As you are not able to see red color on your monitor means you will be seeing green+blue=cyan color your problem is that red signal is not coming to red cathode of your crt. please check 1 connector loose(cpu to monitor) 2 crt base loose. 3 loose or print or dry near red cathode circuit 4 red video output. 5 red signal from processor to red video is missing 6 processor ic. good luck
Sep 27, 2007 | SAMTRON 55V 15" CRT Monitor
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
55 people viewed this question
jasbo
jasbo
