Question about Eforcity Samsung ML-3470DB Compatible Black Toner
Samsung 3470d duplex jam - Eforcity Samsung ML-3470DB Compatible Black Toner
Hp4200 duplexer paper jam
If it jams every time, remove the duplexer and look for a piece of paper on the metal plate as the paper feeds out of the duplexer and back into the machine. Also use a file folder to push any jammed paper out from inside the duplex module.
Mar 14, 2015 | HP LaserJet 4200 Printer
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
What does jam bottom duplex means
Hi the main problem for wc3635 and wc3550, when copier is showing that Jam is in duplex is the broken duplex sensor lever Change the lever and problem will be solved.
Jun 24, 2014 | Xerox WorkCentre 3550
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Iam getting the duplex paper jam error 371 each time i try to print . how do imake the error go. i dont use the duplex at all.
See page 75 of the attached user manual on how to remove a duplex paper jam. If you can't find a paper jam in the duplexer, simply remove the duplex assembly (power off the printer, then power on) and see if that resolves your issue.
(The printer will operate just fine without the duplex assy. installed)
Okidata C9650 User Manual
Sep 12, 2012 | Oki Printing Solutions C9650 Led Printer
Hi, Hope you can help, A CP 6015 jams on dupex 2nd side on entrance to fuser,it looks like something to do with pressure roller release mechanisum as when released an actuator moves across fuser entrance,...
The document I was thinking of referred to fuser wrap jams. I did some quick checking of duplex jams though and this might give you some guidance to check for.
These errors refer to jams when repicking to print side 2.
Cause Solution The spring of the duplexing media-repickup-sensor lever is unhooked Check the spring and place it in the correct position. The duplexing media-repickup-sensor lever is damaged Replace the duplexing feed unit. Poor contact of the duplexing media-repickup-sensor connector Reconnect the connectors of the duplexing media-repickup sensor (J1945), intermediate (J1909, J1950) and the DC controller PCA (J4105). The duplexing media-repickup sensor is defective Check the duplexing media-repickup sensor by the sensor monitor mode. If the sensor is defective, replace the duplexing feed unit. Poor contact of the duplexing repickup-motor connector Reconnect the connectors of the duplexing repickup motor (J1771), intermediate (J1908, J1939, J1941) and the duplexing driver PCA (J4104). The duplexing repickup motor is defective Replace the duplexing feed unit.
Mar 10, 2011 | Office Equipment & Supplies
Appear duplex jam at display samsung ML-2150
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
Jan 06, 2011 | Samsung ML-2150 Laser Printer
The duplexer in our HP printer appears to be jammed. where is it located?
As you face the printer, walk around to the left side. You will see the power switch. Above the power switch is the duplexer. It pulls out.
You said the duplexer is jammed, so you might not be able to pull it out.
Is the duplexer jammed or is there paper jammed in the duplexer?
Dec 03, 2010 | HP LaserJet M5025 MFP Printer
Samsung clp 500
i cant answer but have same problem this printer was around $500.00 & is ****!
Jun 19, 2008 | Samsung CLP-500 Laser Printer
Eforcity Samsung ML-3470DB Compatible Black Toner Logo
Top Eforcity Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Eforcity Office Equipment and Supply Expert? Answer questions, earn points and help others
