Question about Amana Washing Machines
Can i replace the amana timer 37929 for a 37928
Can ireplace the amana timer 37929 for a 37928
  • brigitha Oct 24, 2012
Amana Washer NTW4501XQ0. I have replaced the lid switch, and the timer. The washer still will not run thru an entire cycle. What should I try next
You can try recalibrating unit. With your dial setting at the 12 o'clock position on the timer, you want to do these steps within 7 seconds. Turn timer knob left one time, 3 rights, one left, one right.
Then you will see all the lights blink. ( no time constraints after you see lights blink) Turn the knob 4 clicks to the right, then push the start button. Let it run until you hear the lid unlock and you see the done light lit up. When you replaced the timer, you needed to recalibrate the unit.
Feb 25, 2015 | Amana Washing Machines
Kenmore fridg pops circut breaker,
Sounds like a shorted heater. You advanced manully, unit runs till timer goes to defrost. Timer contacts switch, defrost heater shorted trips breaker.
Apr 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Amana br18v1w bottom freezer iced up will not defrost
rotate defrost timer till compressor off
does it defrost if no then
jump out defrost t-stat (round disc)
if starts to defrost Replace defrost t-stat
if yes replace defrost timer if not turning
Oct 24, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Timer dial gets stuck on Amana dryer.
The only fix is to replace the timer.
Aug 30, 2009 | Amana Dryers
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
My Amana LWA60AW washing machine won't agitate.
Some timer dials will not turn all the time they will sit for awhile then advance . If it don't move for a long time sounds like you have a bad timer motor.
Some motors can be replaced and some you have to replace the complete timer.
Jun 10, 2009 | Washing Machines
Open Questions:
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
