Question about Gateway FPD1975W 19" LCD Monitor
No signal on monitor
Hook up an 2001 gateway pc, it work fine before i unplugged it about 6mts ago now it sts no signal. Double check everything and everything is plugged up correct.
    Problem Solver:
  • 7 Answers
You probably have 2 monitor connections. you have a standard one, and one that is through a graphics card at the bottom of your tower. Check for that second connection and switch the plug.. that should solve it.
Posted on Jan 02, 2009
Hp monitor 2031s does not scan signal from gateway gt5432...
Go back to Dell monitor. Remove any video drivers from hp.change video resolution both in windows and in video card settings to standard 1024 x 768 (yes it will look horrible) then hook up hp monitor. Don't install drivers if prompted get them from hp website then adjust resolution through video card settings after drivers installed which probably require restart.
Dec 01, 2013 | HP Computers & Internet
My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Jun 30, 2011 | Gateway Computers & Internet
I hooked up the monitor and it says "no signal in
Your computer is set to a resolution too high for the display. You have to reduce the resolution to 1024x768, then plug the monitor back in.
Apr 25, 2011 | Gateway FPD 1540 (Black) 15 in. Flat Panel...
I have a gateway gm5478 model pc with a 22inch lcd gateway fpd2275w monitor(purchased 12/07) for family use and the monitor started giving me the no signal display about 3-4 months ago and has increased in...
This could go two ways, neither of them good.
The first possible thing could be that the monitor is on its last legs, and had been dying for those months. You can verify this by trying to hook it up to another PC if possible.
The other possible problem could be that your video card is going. Gateways aren't exactly the most reliable PC, and it could be that the video card has stopped for one or more different reasons.
There's also the chance of overheating, which you can check by feeling the tower/monitor, or downloading this program called SpeedFan which can tell you the temperature inside the PC, provided it came with sensors (some do some don't).
I hope this helps some
Best wishes :)
Nov 29, 2009 | Computers & Internet
Everything is plugged in and turned on. worked two nights ago. was shutoff and has not been used during that time. lcd light is orange. if unplug says self-test. what else can i do
Most likely a cable or video card issue. If its a video car, try hooking it to your computers motherboard vga spot. If it works then you know its a video card. Another thing to try is to run another source to it. When its lit orange, thats a standby mode meaning its not recieving a signal from the source. Good luck.
Nov 10, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway 610 Media Center
I would then suspect the monitor.
Sounds like the video card is working.
Try another monitor to see for sure.
Sep 09, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
No Video Signal
Try resetting the bios. On the motherboard there is a battery that looks like a watch battery. Remove the battery, then replace it again. (make sure the computer is unplugged from the wall socket when you do this)
Does this work?
Oct 24, 2008 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Monitor not receiving a signal
I have these monitors, didn't you get another cable in the pack which has a vga plug on the end? I have had trouble with those converters, try a DVI to VGA cable
Jan 15, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
177 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
