Question about Panasonic Technics Sa-gx690 Av Control Stereo Receiver/ Amp/ Amplifier 100 W Surround
Technics SA-GX690 receiver has no power after experiencing a low voltage power failer. The reset button does nothing.
Is there a circuit breaker or fuse inside the case?
2 Suggested Answers
  • 4234 Answers
SOURCE: My Technics stereo system ...the display screen shows nothing
The question is, do you hear any sound? Is just the display off or is the entire unit shutdown? Can you tell?
These displays are known to develope poor solder connections at the power input and ground pins. If you can solder, open up the unit (unplugged of course) and examine the pins for the display. This will be on the PC board attached to the front panel. The pins at either end of a long line of pins will be the power and ground pins. Reasolder those pins, taking care not to short the pins together and try the unit once done. If that does not resolve the problem (assuming it is just a display problem), update this with as many details as you can about the behavior of the unit and we'll look further.
Dan
Posted on Nov 18, 2009
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
How to reset Technics SA-GX690
See pages 5 & 22 of the manual at... http://www.manualslib.com/manual/119553/Technics-Sagx390.html#product-SAGX690
Jul 04, 2014 | Audio Players & Recorders
Amp keep's sating overload
Have you tried disconnecting all the speakers and inputs and turn it on?
If it still shuts off you have an internal problem, if it stays on, connect one item at a time until it shuts off and that is the problem.
Jan 13, 2013 | Panasonic Technics Sa-gx690 Av Control...
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Speaker hookup for sa gx690 technics
http://www.hifiengine.com/manuals/technics/sa-gx690.shtml
Register for free and download the manual. It's pretty straightforward and everything is marked.
Jul 14, 2011 | Technics SA-DX940
Hi a have too same problems vhen i start reciever, reciever dont " click" and sound isn´t out.Than 15min to 2 hour later reciever "click" and all is o.k. I moved reciever to my friend. He is very good...
There is an internal "timer" circuit that controls the delay of the output relay. The capacitor in this circuit may be defective. Since it is part of an RC circuit, poor solder connections can effect this as well. Look closely at the board for any solder connections that appear grainy or have rings and resolder them. That may resolve the problem. If not, please update this with your findings and I will look up the service manual for this and list the probable defective components in the delay circuit.
Dan
Oct 15, 2009 | Technics SA-DX930 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Panasonic Technics Sa-gx690 Av Control Stereo Receiver/ Amp/ Amplifier 100 W Surround Logo
97 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
