Question about Asrock A785GMLE Motherboard
How do I connect my sd card connector to the A785GMLE? I have an HP Media Center PC.
My computer runs Windows Vista and I installed the motherboard, which run perfectly, except I don't know how to connect the media card drive that's located at the top front of case. I don't see any such connections. Am I wrong?
  • 5,660 Answers
AsRock A785GMLE,
http://www.asrock.com/mb/overview.asp?Model=A785GM-LE/128M
There are THREE USB headers on the motherboard, that have TWO USB connections for EACH header.
Just pick one that isn't occupied.
The power cable is a Small 4-pin Peripheral power cable.
Used in the past for a Floppy Drive,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
[ It is deemed Small, because it is smaller than the Standard 4-pin Peripheral power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Deemed a 'Molex' power cable erroneously. Molex was the first manufacturer of the plug, and it's design. Name stuck kind of like calling an open-end wrench, a Crescent wrench ]
Regards,
joecoolvette
Posted on Oct 25, 2012
  • joecoolvette
    joecoolvette Oct 25, 2012
    Ahem! Kind of like calling an -> Adjustable open-end wrench a Crescent wrench.
sandrew
  • 2961 Answers
SOURCE: Onboard sound doesn't work
click search, then type dxdiag, click the sound tab and a diagnostic programme will check your sound driver and report any faults
Posted on Sep 26, 2007
Kurth
  • 86 Answers
SOURCE: graphics drivers for asrock motherboard
Let Vista install its ownset of drivers - they work fine.
Otherwize download it from the website
http://www.asrock.com/support/Download.asp
Posted on Aug 17, 2008
Geekman
  • 32281 Answers
SOURCE: gigabyte ga-8i915p duo motherboard ide problems
RAID stands for Redundant Array of Inexpensive Disks.
The RAID system uses multiple number of hard disks to give a fast and fault tolerant storage using several disk controllers.
There are various levels of RAID, for info on RAIDs check out
http://en.wikipedia.org/wiki/Standard_RAID_levels
Posted on Apr 03, 2009
SOURCE: 3 beeps on startup with asrock k7s8x motherboard
same here! ASrock sucks!!!! How sad!
Posted on Jan 12, 2010
  • 51 Answers
SOURCE: Hi, I'm having a problem with my sound. Windows says there's not an audio device but i have run the motherboard disc and installed Nvidia high definition audio and still it doesn't seem to
Go to Start - All Programs - Accessories - Entertainment - Volume Control and see if your Maste Volume is at minimum or mute. I had this problem but maybe you have the same problem.
Posted on Apr 28, 2012
How do i use the mmc/sd port
Hi !
First, you have to make sure that you have installed the proper drivers for your mmc/sd port.
http://support.hp.com/us-en/product/HP-Media-Center-m7000-Desktop-PC-series/1847154/model/3185130/drivers
Restart after installing. After that, just insert the mmc into the slot and you should see it on "My Computer" or press Win+E.
May 22, 2014 | HP Pavilion m7570n (EX331AA) PC Desktop
Computer won't read compact flash card
Sounds like a sure driver Issue Marilee, Simply check your device Manager to see if there are any flags in any of the hardware, If the Card reader drivers have not been installed or is corrupted then the card will not work. Please let me know What operating system you are running eg. Windows XP Vista, Windows 7 or 8 and I will give you step by step instructions on how to resolve this issue.
Dec 27, 2013 | HP Presario Media Center SR1950NX...
Required motherboard drivers for hp fc TAJ 81915. operating system windows xp froffetional
If your PC is: ''HP Pavilion Media Center TV m8191.sc-a Desktop PC Bundle Drivers'' , then you only have download support for Windows Vista & 7 driver from HP. Have You tried HP support site: http://h10025.www1.hp.com. As an alternative, You can download and install every component using drivers from third-party sources - that imply assistance from a experienced computer technician.
Sep 03, 2013 | Computers & Internet
Installed a Graphics card EVGA 6200 AGP 8X in my PC HP Media Center PC m370n now keeps showing failure notice
Did you install the drivers for the Graphics Card before you plugged the card into the computer? If not, remove the graphics card and reboot using your old video connection, install the driver then install the card and plug your monitor into the newly installed card. If you still have an issue try booting into safe mode.
Mar 19, 2012 | HP Media Center Photosmart PC (M7160N) PC...
I had to change the motherboard as it failed
Look at the front panel of the computer you will see the connections you have. Should be power, reset, power led, usb etc. These are connected to your current motherboard and most times all the connections will be labeled in the case, on the wire connector ends. IE the end that connects to the motherboard. The only exception to this is the usb ports, and they can be hooked up to new usb connectors on the motherboard. Also note, read i said READ the proper way to connect the usb to the motherboard, this is usually a one shot deal, get it wrong and you kill that usb connector.
Apr 24, 2010 | HP Media Center M370N (DM163A#ABA) PC...
I reformated my desktop and theres no sound on this hp pavilion a6000n i need sound
he has
  • Windows Vista Home Premium
  • Windows Media Center
  • or windows xp and here the website to download the drivers for vista, xp, media centre
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3377269&lc=en&cc=us&dlc=en&lang=en&cc=us
    Apr 15, 2009 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
    Xbox 360-computer?
    To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
    To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
    To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
    1. Start Media Center.
    2. On the Settings menu, click General.
    3. Scroll down, and then click About Media Center.
    4. Click Software Version
      The version number of Media Center you are running is displayed.
    To determine the version of Windows XP that you are running, follow these steps:
    1. On the Start menu, right-click My Computer, and then click Properties.
    2. On the General tab, under System, look for the version of Windows that you are running.
    Oct 05, 2008 | Microsoft Xbox 360 Console
    Asrock A785GMLE Motherboard Logo
    Top Asrock Computers & Internet Experts
    David
    David
    Matthew Spark
    Matthew Spark
    Computer Links
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
