Question about Dual Electronics Gatekeeper Ltd yG5602 Dual Swing Gate Opener
Does any one knows about the gatekeeper ltd YG5602
Can it be reset
Benefits of Having a Security Guard at a Business?
you have asked this question many times over a week. whats the problem???
Aug 01, 2017 | Computers & Internet
I reset my dvr ltd 7908 and cant get the password again
try "admin".
is the default password for everything.
Feb 13, 2015 | Home Security
I have a 3com router. there is no reset button in the back as i have seen in other models. i just want to be able to stop it from needing a password so i can use all these new things that need a wireless...
I would be very suprised if there isn't a reset button, I've never seen a router without one. It would be in a little hole just big enough for a pencil point to go in.
However, are you sure you want to reset it, as that would stop it connecting to the internet?
If you just want to turn off the wifi password (which is what it sounds like you want to do) then you have to access the router's internal set-up routine which is normally done through your web-browser.
Enter the IP address of your router into the brower address line - it will start with 192.168. and will end with either 0.1 or 1.1 or 1.254
You will generally come up against a gatekeeper page that asks for the username and password. Unless they have been changed these are usually admin and password or admin and admin. ,
Once past that you get access to the set-up pages. Locate the WLAN section and turn off the security. make sure you hit any Apply buttons before you exit the pages.
That should be it.
post back to let us know if that worked.
Jul 13, 2011 | 3Com OfficeConnect Wireless Router
I need to know how to reset my phone
Hi! this will do a hard reset on your mobile phone. Hope this helps Fazal Enterprise Ltd - www.fazalenteprise.co.uk
Power off phone. If it won't turn off, take the battery out.
2. Press and hold the Powerand Camera button at the same time. Release theCamera button when prompted.
3. Press Volume Down key.
4. A yellow triangle will appear. Press on the screen just above the back key.
5. Select option wipedata/factory reset (Alt + W).
Hope this helps
Mar 02, 2011 | Motorola Mobility Backflip Smartphone
I can't find my wep key info., and I need it to install Tivo. How do I find my wep key? I have netgear. Please don't tell me to type http://192.168.1.1. Once there I still need my wep key information to...
OK Connect your computer to the router with an ethernet cable.
Type 192.168.1.1 in the browser and then return.
Then type in the router's gatekeeper codes. Unless they have been changed they are admin and password.
Then when you have passed the gatekeeper, look down the left hand side for the wireless setting tab. Click on it.
When the page opens scroll down to the security section AND THERE IS YOUR WEP KEY. Generally it's the first of the four. Normally it will have the bullet marking it.
Your WEP key is only used by the wireless side, It is not used to access the settings of the router.
May 30, 2010 | NetGear WGR614 Wireless Router
I want to use this phone in india purchased in USA, pls advice
Yes you can use that kind of phone in India. All you have to do to make it operable is to buy a sim card that belongs to India country Telecommunications company which offer services to your phone. Below is the list of India Mobile Service Providers.
Cellular Mobile Telephone Service Providers
  • Bharti Cellular Ltd
  • Sterling Cellular Ltd
  • BPL Mobile Communications Ltd
  • Hutchison Max Telecom Ltd
  • Modi Telstra Pvt. Ltd
  • Usha Martin Telekom Ltd
  • RPG Cellular Seravices Ltd
  • Skycell Communications Pvt. Ltd
  • Airtel Digilink India Ltd
  • Fascel Ltd
  • Hexacom India Ltd
  • JT Mobiles Ltd
  • Koshika Telecom Pvt. Ltd
  • Tata Communications Pvt. Ltd
  • Escotel Mobile Comm. Pvt. Ltd
  • Bharti Telenet Ltd
  • RPG Cellcom Ltd
  • Modicom Network Pvt. Ltd
  • Birla AT&T Comm. Ltd
  • Reliance Telecom Ltd
  • BPL Cellular Ltd
  • Srinivas Cellcom Ltd
Source: India Telecom
Hope this helps..
Mar 30, 2010 | Sony Ericsson W910i Cellular Phone
Reset DLink router to factory default
All you need is your ISP log-in name and password.
Connect the router to your computer with an ethernet cable, log into its web server (generally 192.168.0.1) Get past the gatekeeper (admin and admin) and then navigate to the set-up page and re-enter your ISP info. That normally is all there is to it.
Nov 21, 2009 | D-Link Computers & Internet
My brakes lights wont work! bulbs are fine! just dont know what fuses are which!
if your 1990 ford LTD is anything the same as my 1989 ford LTD then your fuse is in position "4" on the fuse panel
Apr 16, 2009 | 1990 Ford LTD Crown Victoria
Dual Electronics Gatekeeper Ltd yG5602 Dual Swing Gate Opener Logo
22 people viewed this question
Top Dual Electronics Home Security Experts
Lawrence Oravetz
Are you a Dual Electronics Home Security Expert? Answer questions, earn points and help others
