Question about Quincy Compressor Quincy 30 Rotary Screw Air Compressor Qmb W/ Spx Hankison Dryer Model H115
Quincy model model QMB/T is leaking oil out of filter
    Top Expert:
  • 49,967 Answers
Tighten filter
check that the filter is not too tight and distorting the seal
replace the filter
Posted on Nov 23, 2015
How do you replace the check valve on a
using a small pipe wrench on ck valve body unscrew it by using ends of valve itself (lefty loosly) make sure to install new one with arrow pointing towards tank (important) and use a bit of teflon tape on threads to act as a seal take care not to crush body with wrench as this will affect valve working try and only use wrench on ends of valve
Apr 24, 2014 | Quincy Compressor Quincy 30 Rotary Screw...
Air Compressor
No that is not the oil filter. The oil filter # is 110814-001 comes 6 to a pack.
Apr 11, 2014 | Quincy Compressor 110382D075 0.75 NPT...
Compressor shuts down and will not allow enough pressure run machine
Sounds like the oil is low or the cooler is dirty. If that's not the case then you have a defective thermal valve.
Dec 17, 2013 | Quincy Compressor Quincy QGS Rotary Screw...
How much oil for a quincy compressor model #216
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Mar 24, 2013 | Honda Quincy 17 - Gallon Air Compressor...
My oil temp has gone from the ave of 140 to 152 in about a week. everthing else is normal
check oil level in unit as over full will over heat oil. It is possible that there is a failing bearing or bush. Check outlet pipes for blockages from carbon build up from un burnt sump oil.
Jan 28, 2013 | Quincy Compressor Quincy 5 Air Compressor
Where is oil sensor on honda gx160 5.5
The low oil sensor is on the front of the block the wires are attached to ur start stop switch. It has two wires yellow and black on most models. the sensor itself is internal
Dec 11, 2012 | Honda Quincy 17 - Gallon Air Compressor...
What kind of Oil would you use in an Quincy Compressor Model 340???
30W Non-Detergent. You can get it at hardware stores or tool stores. You can go with synthetic if you like, but if you don't run it too hard, regular oil is fine.
May 26, 2011 | Air Tools & Compressors
Oil filter leaking i did got new oil filter but still leaking
Hi
Are you sure its the oil filter? it could be the oil filter gasket, some models/ not all vw have a second gasket seperate from the oil filter itsself, the other thing is the oil could be leaking from the top of the engine but then dripping off the filter making you think that, that is the cause.
Is the oil filter to the rear of the engine or up front? what model, year and engine size?
Regards
Dan
Nov 18, 2010 | Volkswagen Jetta Cars & Trucks
Compressor has no oil pressure but seems to be running good
If you're sure its not just a bad oil pressure gauge, and there is no pressure, the oil pump is probably bad. If you don't run it hard, it may still last awhile, running more like a "splash lube" compressor. Still, if this is a pressure lubed Quincy, it's a good compressor - I'd fix the oil pump and it'll last for years.
Dec 15, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Quincy Compressor Quincy 30 Rotary Screw Air Compressor Qmb W/ Spx Hankison Dryer Model H115 Logo
187 people viewed this question
Top Quincy Compressor Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Quincy Compressor Tool and Hardware - Other Expert? Answer questions, earn points and help others
