Question about D-Link DP 301U (DP-301U) Print Server
I have a d-link DP 301u can't print to printer
I send a test print it goes to the printer queue and it says it sent to printer but printer has no response and the usb light on the print server does not light. And then the job is out of the queue. Any ideas?
  • 1 more comment
  • grye Jan 05, 2009
    As of today, I have exactly the same problem
  • grye Jan 05, 2009
    The computer fails to ping the print server...
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you able to see the print server on the network using the tcp/ip address assigned to it?
Found it just not to be a good product could not get it to work properly.
Took a netgear ps121 and had it connected and working in less than 5 minutes and could use the manager sofrare that came with the printer.
Posted on Jan 07, 2009
I solved my problem. I switched off the netgear rooter for several minutes to reset it. Just switching it off and on doesn't work.
Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
Print command accept but not printing
cheers!!
Aug 10, 2009 | D-Link DP 301U (DP-301U) Print Server
No documents are sent to the print queue when attempting to print to a printer through a DP-301U. Printing in Vista works fine, but not so much with XP.
Check and see if the drivers are installed correctly and configured on both pc's.Then see if the printer is installed and that sharing is enabled on the network. Mike tekman2300@yahoo.com let me know when you complete these steps and if it worked.
Aug 08, 2009 | D-Link DP 301U (DP-301U) Print Server
USB printer HP 1020 Plus in DP-301U
Did you try using LPR mode instead? I find it works more relyable with any print server. SMB (windows network mode) is ****. I have had simalar problems with another printserver.
Apr 17, 2009 | D-Link DP-301U (790069251979) Print Server
Print server DL-301U setting
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
D-LINK PRINT SERVER DP-301U AFTER DOING A SYSTEM RESTORE ON MY DESKTOP COMPUTER (WINDOWS XP) I CAN NO LONGER PRINT TO MY SAMSUNG ML-2010 SERIES PRINTER ... PRINT JOBS ARE IN THE PRINTER QUEUE BUT WON'T...
- Kindly visit this web site for instructions:
http://support.dlink.com/faq/view.asp?prod_id=459&question=DP-100%20/%20%20DP-101P+%20/%20DP-300%20/%20DP-301P+%20/%20%20DP-303%20/%20DP-313%20/%20DP-301U%20/%20DP-311P%20/%20DP-311U%20/%20DP-311U_revB
Mar 12, 2009 | D-Link DP-301U (790069251979) Print Server
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    DP301U COMPATIBILITY
    I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
    LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U Print Server not continuous print from vista
    Make sure you have byte counting enabled if you are printing through LPR.
    Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    802 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
