Question about Car Audio & Video
CD changer in my 1998 Saab Estate will not eject? Anyone?
Magazine will not eject?
    Top Expert:
  • Car Audio & ... Master
  • 35,572 Answers
You may have a CD stuck part way between the player mechanism and the magazine. You can try loading and unloading several times to correct the problem but in some cases the only cure is disassembly
Posted on Oct 25, 2012
SOURCE: Problem with stuck magazine....
OK I have had exactly the same problem and spent the last hour or so fixing it. It seems to have its logical knickers in a twist after the battery going flat and won't eject because its left a CD in the playing position, IE, out of the magazine. So, remove the changer from the car (usually velcro then pull off the two phono and the power connectors) and undo the four small cross head screws holding the case on. Pull the front panel off (you may need to pinch the case in the middle top and/or bottom as there is a clip here holding the front panel), then either pull the sides of the case out until the two rotary Horizontal/vertical mount controls disengage (or you may be able to rotate them anti-clockwise until they pop off, but I didn't try this) and lift off the lid. Next, pull the four little mounting posts on the internal deck assembly out of their four rubber mounts on the outer case, and disengage the two springs from the horizontal/vertical mounting controls. The mech is now loose inside the case but be careful as its attached by a rather delicate ribbon cable to the outside cables and connectors, This will unplug after you pull off the sticky tape holding it to the chassis, but you might be able to do the rest of this without unplugging it if you turn the mech over carefully. You will see a motor assembly and several white cogs (actually you will see two but the little tiny one with a worm (spiral) drive only moved the CD mech optical head so ignore that one). Using a small screwdriver, carefully rotate the cog closest to the motor so that (viewed with the motor closest to you and to the right) the plastic parts under this assembly start to slide to the right. You should actually be able to see the CD underneath start to move to the laft, back into the magazine, and the CD mech will open up to release it. Once the cog doesnt want to turn any further (and the CD is completely back in the Mag), then you will be able to manually eject the mag by pulling sideways gently on a round white part on the mag side. The mechanism should click and release the mag. Hey presto... fixed. Now just reassemble the whole thing back into its case, probably a good idea to check that each of the CD's is correctly seated in the mag and that there is nothing wrong with any of them that could cause it to jam again, then go try it in the car prior to final assembly. As we now know that this unit seems to be prone to throw a wobbly if its power is removed with a CD in it, I would strongly recommend that you eject the mag before disconnecting the unit for final assembly, assuming it all works OK now, or indeed any time you might have to disconnect the car battery for any other reason. Hope this helps, it did it for me! Mark
Posted on Jan 21, 2007
Eagleeyes
  • 199 Answers
SOURCE: Inoperable CD changer
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Posted on May 03, 2007
Eagleeyes
  • 199 Answers
SOURCE: factory installed Alpine 6 CD Changer- cd magazine (for 1998 BMW 528i E39)
Hi , seen lots of these.
whats happend is the Tray that the disc sits in has jammed halfway in.
in most cases giving the mag a swift tap (hard tap) with the haddle of a screw driver , while pushing the eject button normally is just enough to dislodge the mag.
otherwise its a repair job.
were do you live Alison?
Regards
Mark
www.blueice-electronics.co.uk
Posted on Jun 23, 2008
SOURCE: Remove CD Magazine - No power to unit!
I fixed my similar problem by applying 12v to the unit according to the pinout found here:
http://users.ntplx.net/~andrew/sony/unilink/
(note that -12v goes to the connector barrel)
Posted on Apr 06, 2009
SOURCE: Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Posted on Apr 15, 2009
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
u need to re-connect it in order to remove the magazine
Jun 15, 2008 | Sony CDX-646 10-Disc CD Changer
My 04 yukon cd changer won't eject the cd. any advise?
if you push the eject cd magazine button on the changer does it sound like it's trying to eject it? if it doesn't you'll need to replace the changer. if it does, then you've got a stuck cd magazine tray. it sounds weird, but when i was working on land rovers this happened all the time on the full size range rovers. what we did was push the magazine eject button on the changer to eject the cd magazine and sort of slap the changer around a bit. 90% of the time it worked. the other times, we'd go in with a 90 degree pick and try to push the stuck cd tray back into the magazine (while it was still in the changer) while pushing the eject magazine button on the changer. and you'll need to replace the cd magazine. if it happens again, you'll need to replace the entire changer.
Feb 16, 2010 | Car Audio & Video
My dealer installed Saab CD changer is not functioning properly.
The unit is having internal firmware problem. It may be off track or have a bad capacitor. You will need to dismantle to cover to receive your cd tray. There may also be a problem with the lens.
Jul 17, 2009 | Honda Auto Changer Board
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
How do you eject the magazine
Press and Slide Front half cover as shown in below image and you will see eject button there to eject magazine.
May 04, 2009 | Sony CDX-T69 6-Disc CD Changer
Apr 14, 2009 | Car Audio & Video
How do I reset CD changer?
I disconnected the car bettery for a minute, reconnected and was then able to eject the magazine.
Sep 29, 2008 | Sony CDX-T67 6-Disc CD Changer
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
