Question about Whirlpool Washing Machines
Whirlpool fl 5103 pump problem
Changed the pump but still not pumping water out from drum. Program problem?
  • 1028 Answers
SOURCE: Whirlpool/Kenmore Calypso Washing Machine FL code
not overfill since no water overtop just switch detecting too much water...lean washer back remove 3 screws holding bottom panel on newer pumps have torx screws in bottom id any way possible remove a much water as possible first may try leaning washer foward after removing bottom panel remove the screws in bottom of pump and clean..older pumps were harder to clean and replacement was easier but more expensive..new style comes with motor attached
Posted on Jul 17, 2008
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
SOURCE: drum will not drain
There is a rubber boot from the wash tub to the pump. At the tub end of the rubber boot is a plastic ball slightly larger then a ping pong ball. The space around the ball was plugged with paper towel. The paper towel pieces were removed and the unit reassembled. Access to the rubber boot required removing both the front and back panels.
Posted on Apr 29, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
ned_san_jose
  • 234 Answers
SOURCE: Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Posted on Jul 19, 2009
Fl 243 500
Yes. Open the small front top toe cover, you will see the pump there, remove the filter and check if all the blocked stuff in there. Squeeze the hose connecting from the drum to pump to find if any small stuff was tucked there.
Oct 09, 2013 | Whirlpool Duet GHW9150P Front Load Washer
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool front loader it gives me a
Flood Condition:
Mar 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Caypso Washer is flashing FL
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&!$$
Dec 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code and 1" of water won't drain
Every time mine does this it has strings stuck in the pump. Remove the pump and either take it apart on puld the junk out of it it or do what I did and go to FirstSource pay 10% for a life time waranty and buy a new pump. I've replace it about once a year. Check the seal around the swashplate in the bottom of the drum it may need to be replaced along with the u-joint. If this is worn it allows more **** to be sucked into the pump. I never buy whirlpool again. I have 2 appliances that give me constant grieve a whirlpool flame lock water heater and this expensive piece of junk.
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool top loader with calypsoTM wash motion. The machine showed Off Balance I had to start over them the machine showed ''FL'' over Fill. I turned the water off and have tryed to get the...
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Feb 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Kenmore Calypso top loader
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$#@!
Jan 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso top load washer getting FL error message
fl,,flood condiction,,the pump is trying to get out the water,,replace or try and un block pump..onthejob
Jan 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
FL error on my Whirlpool washer
Flood Condition:
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Fl display on washer
possible but may be a pump issue as well ckd pump first..pump comes off motor if it has never been changed before ..if it has been changed new style has 4 torx screws remove as much water as possible tilt machine back remove screws and look for something in pump old style pump had plastic splines that would strip slim chnce but could be issue with water level switches or ever present control board commuication problems
May 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
