Question about John Deere Garden
John deere 2130 operators manual
Operators manual
blueextc3221
  • 15935 Answers
SOURCE: system creeps down even when tractor is operating.
There are 2 potential problems -
1. Leaking spool on the control valve - rebuild the vale.
2. Cylinder blow-by. Disassemble piston and replace the seals.
To test if its the cylinder - retract the cylinders all the way... remove the hoses on the blind end (non rod end) of each cylinder, and again pull the valve to the retract position.
If fluid continues to pour out of the cylinder - the piston seal is damaged, and the affected cylinder must be repaired.
To test if the valve spool is faulty - disconnect the a and b ports just after the valve. Turn on the system and check for seepage from the disconnected lines (without moving the lever).
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 19, 2009
  • 138 Answers
SOURCE: need an owners manual for a john deere lawn LT-133
you can go to www.deere.com and then click on residential equipment on the next page click on services and support and then enter your model number you will need your machines serial number to choose which model you have. here you view on online or order a new copy on cd
Posted on Sep 06, 2009
SOURCE: need owner's and service manuals for John Deere Model 317/
First off, Mowerman's response was incorrect about the age of a JD 317.  They were made from 1979 to 1982.
You can only get manuals either through here:  http://techpubs.deere.com/deere/Default.aspx  or from a dealer.  They're expensive.  You can find them on ebay and also here: http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=317%20Hydrostatic but I haven't used that site.
Posted on Oct 27, 2009
wireguy212
  • 1627 Answers
SOURCE: does a 1978 john deere 2130 have a 2 speed pto and
Remove the clip from the pto shaft by squeezing it shut,push it in some then pull it out.Turn the shaft around and put it back in making sure the clip snaps back in place.
Posted on Nov 10, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 425 AWS no start, no nothing???
If engine cranks over and have no spark try a time delay module located under thermostat housing.
Posted on Nov 13, 2009
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM136969.../OMM136969_L013.htm...
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
Where do u place the attachment lift lever on a john deere L130 r where can i find a diahgram for it
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMGX21647.../OMGX21647_K35.html
Picture Note: Console on Models L120 and L130. A - Throttle ... Put attachment lift lever (A) into the slot adjacent to desired cutting height. · Slide the height ..
Aug 18, 2015 | John Deere Garden
Find the year of my John Deere tractor model 2130 Serial#CD 4239 D 764428
Try looking under the tracter thats where i found mine on my 3ds
Mar 04, 2015 | John Deere Garden
No operators manual
I doubt your going to find a free manual for anythng John Deere makes let alone an older tractor. However..... You can get an operator's manual direct from JOHN DEERE by calling 1-800-522-7448 with credit card in hand.
A bit about the tractor itself. Note the links On the linked page below:
http://www.tractordata.com/farm-tractors/001/8/0/1801-john-deere-1640.html
Again.. even with a source as good as that webpage you do not see an Operator's or an Owner's manual link.
IF your doing a course at a local college, try the college bookstore first. The manual will be much cheaper than buying it from John Deere.
Thanks for using FixYa,
Kelly
Apr 21, 2010 | John Deere Tractor 1020, 1520, 1530,...
Does a 1978 john deere 2130 have a 2 speed pto and how do you change speeds
Nov 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
152 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
