Question about Maytag 24 in. MDB9750AW Dishwasher
Maytag dishwasher start light blinking but dishwasher wont restart cycle
I have drained the unit and also replaced the locking/latch device.
SOURCE: maytag dishwasher wont start
Drain the water out of the dishwasher. The high water switch ius engaged, lowering the water will disengage.
Posted on Sep 11, 2007
SOURCE: Maytag Dishwasher Latch Sticks
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
Posted on Sep 12, 2007
  • 3422 Answers
SOURCE: Dishwasher won't start
If the unit won't start, but "hums", then the motor itself may need replacing (you need to check for 120V at the motor harness). If the control itself is bad, then you would have to replace the control. You mentioned that the door didn't work right - if that is the case, the door switches may not be making contact properly, thus preventing the motor from starting (the door has to be closed properly for it to start).
If you have any other problems please ask me.
Goodluck,
Please don't forget to rate me as fixya
Posted on Feb 09, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
  • 219 Answers
SOURCE: Maytag Model # MDB7600AWW door will not latch
double check door latch make sure connections are proper if right and still not working probably main board and panel
Posted on May 01, 2009
Just bought a DW80H993 diswhasher and installed it. It will not run a cycle.
Hello. Please provide more specific information--the Samsung dishwasher you have has a child lock and delay wash feature on it--make sure neither is enabled--When you attempt to start a cycle, do you see lights on the control panel? Does the unit do anything at all or is it totally dead with no lights lit up? Are there any lights blinking or blinking in numeric patterns(ex 2 blinks, then 3-4 blinks)? Is the hot water turned on to the unit from under the sink? If the drain hose is connected to a food disposer, did you remove the knock-out from the drain hose connection inside the disposer prior to starting a cycle? These are important pieces of information needed to form a diagnosis as to what might be occurring. Thanks!
Nov 08, 2015 | Dishwashers
Samsung dishwasher dmt 300rfb wont drain and is humming
Hello Randy Lowe,
There is an EXPECTED INITIAL failure period
on new equipment...!!
Use your warranty...
Brand new = Take it back & get a GOOD ONE.
Carnac the Magnificent
Apr 22, 2017 | Samsung DMT300RFS Builtin Dishwasher
Maytag dishwasher mdb7100aws is flashing clean-lightwash-heated dry
I have a Maytag MDB7100AWS which suddenly started blinking the following LEDs: Clean, Rinse Only, Regular Wash, Tough Scrub and Heated dry. Tried cycling the breaker, no help. Tried the key sequences in the troubleshooting sheet behind the kick panel, no help. Then happened to press the Drain/Off button twice. All LEDs went out and am now on my second successful load, fingers crossed. Suspect the control board got latched up somehow.
Jan 25, 2012 | Maytag Dishwashers
My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
Hello
Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
Look at the water valve that is connected to the dishwasher and ensure it is turned on.
Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
Sep 11, 2011 | Kenmore Dishwashers
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
Power surge here and had the same problem
sounds like a bad door latch.the unit thinks the door is open
Jul 24, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher wont run after pressing START ... green light blinks
NOT TOTALLY SURE ABOUT THIS MODEL, BUT IS THERE A "LOCK" BUTTON ON THE PANEL? ON SOME MODELS YOU NEED TO PRESS IT TWICE TO ENGAGE START. HOW OLD IS THE UNIT? HAVE SEEN THE INTERNAL TIMER RELAY MALFUNCTION ALSO AND IT WILL NOT ALLOW DISHWASHER TO START CYCLES. HOPE THIS HELPS
May 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Water is not coming into my Maytag dishwasher.
Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag 24 in. MDB9750AW Dishwasher Logo
446 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
