Question about Health & Beauty
Tga eclipse scooter how do I change battery's
5 Suggested Answers
SOURCE: we have lost the instruction manual for a TGA
If you contact TGA 01787 882244 they would be able to provide you with a manual, it is chargable though.
Posted on Jul 19, 2010
SOURCE: my tga superlite scooter continuosley beeps when
Check that the scooter is in gear and not free wheel mode.
Posted on Sep 14, 2009
ZJLimited
  • 17970 Answers
SOURCE: my TGA eclipse mobility scooter
Sound like a electrical problem
Keep in mind the new device and its possible that you have warranty for this, you can reach they using the contact details below:
Scooters Mobility Ltd
Suite 3
40 Melton Road
Oakham, Rutland
LE15 6AY
T: 0845 273 9717 (local rate)
F: 01572 801 075
E: info@scooters-mobility.co.uk
Try this before to do something, you could lost the warranty..
Keep us updated.
Posted on Mar 31, 2011
gfreed100
  • 60 Answers
SOURCE: i've recently bought a new tga sonet scooter, it's very noisy, they tell me that they are a noisy scooter can anybody tell me if this is true.
Block the rear wheels up off the floor. Now put the sccoter in gear and let her rip! Is it real noisy? Did they replace the motor or the trans-axle on which th motor is appart of. If they replaced the entire assembly and its still making noise, thats what they sound like. Ive heard some of the scooters make a winning sound. Go to a place that sells this model and compare. My scooter is a Rascal 600t it makes some noise. It shouldn't be too noisy though. Its hard to tell from here.
Posted on Jul 13, 2012
TGA Mystere mobility scooter. Scooter drives perfectly but drains batteries within 5 minutes of driving. Have tested with brand new batteries but still does the same. Help!
Hi again ring TGA PARTS FOR A PRICE ON CONTROL BOX 0117 329 1740 good luck i think u need to check THE BATTERIES condition buy a BATTERY LOAD TESTER .OF E/BAY COST APROX ,$35 ,.THIS WILL GIVE U A TRUE READING ON THERE CONDITION,,. Cheers
Dec 27, 2016 | Health & Beauty
Our tga eclipse is constant beeping and flashing 5times.trouble shoot says free wheel mode...have checked this what can be wrong?
There is a micro switch on the brake unit, make sure the freewheel lever is hitting the switch.
Oct 17, 2014 | Health & Beauty
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
TGA mystere mobility scooter error code 02 battery fault showing without key in ignition
Hi Dont know about Error 02, byt if scooter is less than 1 year old get the people you got it from to fix it under warranty,
Jan 28, 2013 | Health & Beauty
Batteries say fully charged on charger but only 1 red flashing light and the green
Hi okay if the red light is flashing , make sure you not in freewheel mode, it could be that the batteries are low , leave on charge for about 4 hours and test again.
Make sure the connector plug that fits from the frame to the handlebars is a good fit, this supplies power to the controller.
Regards
Dec 13, 2012 | Health & Beauty
We have lost the instruction manual for a TGA mobility scooter. The numbers on the scooter are 991186017 and also, AFIKIM Electric Vehicle.
Jul 15, 2010 | Health & Beauty
Where and how do I replace my battery for my pride gogo ultra travel scooter
Do not use batteries with different amp-hour (Ah) capacities. Do not mix old and new batteries. Always replace both batteries at the same time.
MANDATORY!
Battery posts, terminals, and related accessories contain lead and lead compounds. Wear goggles and gloves when handling batteries and wash hands after handling.
WARNING! Always use two batteries of the exact same type, chemistry, and amp-hour (Ah) capacity. Use 12 Volt deep cycle batteries.
1.Remove the battery pack from the Travel Scooter.
2.Carefully turn the pack upside down.
3.Remove the eight (8) screws from the perimeter of the battery pack.
4.Carefully turn the pack right side up and remove the lid.
5.Disconnect the black (-) and red (+) battery cables from the battery terminals.
6.Remove the old battery.
7.Place a new battery in the battery pack.
8.Connect the red battery cable to the positive (+) battery terminal.
9.Connect the black battery cable to the negative (-) battery terminal.
10.Position the lid back onto the battery pack ensuring all wires are inside the pack so they don’t become pinched.
11.Carefully turn the pack upside down.
12.Reinstall all screws and tighten.
13.Charge the new batteries for 8-14 hrs before the first use.
I hope this helps and good luck!
Feb 24, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Health & Beauty Logo
81 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
