Question about Admiral Washing Machines
SN 8525660 can you match that to a model # - Admiral Washing Machines
When was my Winchester 94 30-30 made? Serial no. 2050464
according to this site it was made in 1954, I'm thinking that the the enter column # is the beginning sn for that year.
choose your model on the left,
then scroll down to 54 you will see the sn beginning in the 200's & in 55 the beginning sn in the 207's.
Serial Number Data
Feb 23, 2015 | Winchester Model 94 Short Rifle .30-30 20...
Ordering disk
I had the same problem but with another item I needed, and when I called and asked they told me to only use the first part of the sn (basically use the sn you have but when it fills the allowable space simply stop at that point, they tell me the last part of the sn is not needed to order parts and disks, only for ordering exact replacements that is unique to a exact model.
Simply start at the beginning of your sn and when you cannot put any more of it in, stop and use only what you have entered.
Nov 15, 2013 | E-Machines eMachines Desktop PC
Rheem heat pump
Model number of the inside unit is required
Jul 02, 2013 | Water Heaters
Broken tines on honda tiller fr650 model need part numbers for left and right tines, or location near or in Concord NC I can purchase them.
I will supply you with the part no. I have:
06722-777-000 TINE KIT, ROTARY
72100-777-013 TINE ASSY., R. (OUTER) Use up to Frame SN 1021912.
72100-777-023 TINE ASSY., R. (OUTER) Use from Frame SN 1021913.
72150-777-003 TINE ASSY., R. INSIDE Use up to Frame SN 1021912.
72150-777-013 TINE ASSY., R. INSIDE Use from Frame SN 1021913.
72200-777-013 TINE ASSY., L. (OUTER) Use up to Frame SN 1021912.
72200-777-023 TINE ASSY., L. (OUTER) Use from Frame SN 1021913.
72250-777-003 TINE ASSY., L. INSIDE Use up to Frame SN 1021912.
72250-777-013 TINE ASSY., L. INSIDE Use from Frame SN 1021913.
Hope this helps. Make sure you verify the frame serial number. The tine assy. include the hubs and mounting hardware.
Feb 24, 2011 | Garden
I NEED TO KNOW WHERE TO PURCHASE A O RING FOR MY FOOD PROCESSER, IM IN CANADA
I'd go to the local hardware store, look in the plumbing section and just match it up. If not, any appliance store should be able to match it for you - just bring the processors model/SN with you.
Jan 24, 2011 | Microwave Ovens
How do I add a password?
the password for 2wire if you got it from your ISP is most likely on the bottum of the unit on a sticker
Jul 28, 2010 | 2wire (1000-400108-001) Router
How to undo Child Lock
the key "POWER" +"TV/AV",
Oct 24, 2008 | Televison & Video
Washing Machines Logo
49 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
