Question about Epson Office Equipment & Supplies
Epson dfx9000 it gives me paper jam
Paper jam
  • 3 Answers
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER*********
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Posted on Oct 24, 2012
doc_delphi
  • 11 Answers
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
Posted on Sep 17, 2008
57 varieties
  • 1653 Answers
SOURCE: EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Posted on Aug 29, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
  • 4 Answers
SOURCE: Epson NX415 Paper jam. I took paper out but it's
Check for other bits of ripped off paper stuck in your machine.
Try turning off your printer for 30 secs and turn it back on.
Posted on Apr 25, 2010
jas247
  • 844 Answers
SOURCE: my epson workforce 610 had paper jam and I had to
Welcome to FixYa.
Open the Automatic Document feeder and look for any paper left inside. If you forcefully removed the paper without opening the feeder, a mechanism could possibly occur in which case, servicing the printer is the best option.
Press OK, YES then OK to clear the jam message.
Note: For Legal Size paper, load up to 10 sheets only. For Letter Size paper, you can load up to 30 sheets. This is to prevent paper jams.
Thank you for using Fixya.
Posted on Jun 25, 2011
Epson dfx- 9000 saying ribbon jam. What is the problem?
Usually caused by the ribbon feed unit. The gears strip out and stop working. Sorry about the pic, Fixya is pulling up the wrong picture.
EPSON 1410868 RF UNIT DFX9000 Refurbished
Nov 20, 2015 | Epson Office Equipment & Supplies
Epson DFX9000 printer is printing blank pages
On mine it was to turn off the printer. Then while holding down the paper feed button, press the power button. Let go of the paper feed right away as soon as you hear it start up. When it's done you should get a printout with a number at the top.
OR
Still Having Epson Printer Problems Then follow Us On: Epson Printer Support
Jan 27, 2014 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Epson dfx9000 ribbon jam errors
There is a sub-board under the carriage assy. that controls all the functions. It has probably gone south.
Nov 28, 2011 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Missing some paragraph lines while printing text files on my Epson DFX9000
are you running out of ink? printing at draft quality? head cleaned maybe?Or
Follow Us On For Online Support For Epson Printer Support
Sep 08, 2011 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Epson printer dfx9000 problem ribbon jam errorr i change the ribbon cartridge and test in another printer my ribbon is correct but in this printer this error is shown yet what should i do?
Check for any foreign objects that could be affecting the ribbon cartridge assy ,clean and reset ,perform a maintenance check via the printer menu
Feb 03, 2011 | Epson DFX-9000 Matrix Printer
Left front (as you face printer)tractor feed broken need repair manual to replace part
i has just met a problem "ribbon jam" on machine epson DFX9000 . Please help me to solve this problem . Thanks
Oct 23, 2008 | Epson DFX-9000 Matrix Printer
Dfx9000
Internal hardware detects that the paper paths do not switch during paper path switching operation.
Check HCPP sensor or call for service.
Phone Number:
(562)276-4322
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
EPSON DFX9000
The error code and the lights indicate a fatal error inside the printer. Actually, this is for service already so you need to check the warranty of your printer or call EPSON. I would like to give you some idea on what's happening with your printer. This is something to do with the LES or the left end sensor is not beginning detected. It is when you turn the printer ON/OFF or during normal operation that the left end position is not reaching where the sensor signal should be detected. There might be a need to replace a part of the sensor and its connector or the ROM BOARD itself. Again, please check this with EPSON certified service center.
May 23, 2008 | Epson DFX-9000 Matrix Printer
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
