Question about ASUS Eee Pad Transformer TF101A1 Tablet Computer
How to output 1 to data projector for display
Depends on the ports on the projector, but doesn't the eee pad have a HDMI port on it?
Posted on Oct 24, 2012
I have a Galaxy Tab 2 10.1 and I wish to reset my password.
NOTE: You may have to wait 30 seconds-1 minute when performing each step.
If you don't want to lose DATA there may be a "Forgot password?" option in which case google will reset the password via your email. If this option is not there then follow these steps.
To perform factory/hard reset please follow those steps (you will lose everything):
1. Turn the power off.
2. Press and Hold the Volume Up and Power button at the same time.
3. When the start up screen show (Samsung logo displays on the screen), release all the buttons.
4. Use the Volume Up/Down button to navigate to "wipe data/factory reset", select with Power button
5. Select "wipe data/factory reset"
6. Select "Yes -- delete all user data"
  • Allow several minutes for the factory data reset process to complete.
7. Select "reboot system now"
  • Allow several minutes for the reboot process to complete..
  • This is all i could find on the internet so not sure if its what you are looking for.
Nov 18, 2016 | Tablets & eReaders
Ineed a dc5vv2.0a that came with it I get other for it and do'not work and the usb is not work if did not come with the moblenab12-nv7a please help
If using the supplied / original BLACK and WHITE USB cord, the black must be used for charging. The white is for data transfer only and lacks connections for power / charging.
Most USB chargers will output 1 amp or less. Many USB jacks on computers output between .5 and 1 amp - max. Your device calls for a charger with 2 amps output. Connecting to devices such as those mentioned above can overload and damage the charger or computer - don't use them!
USB ports have standard connections or "pinouts". You should obtain a USB charger (5V DC) rated for 2 amps (or more for better performance). Be sure to select one with matching USB connector (compatible with your device) - mini, micro, etc.
Amazon has several from which to choose:
Amazon com nabi2 nv7a charger
Nov 12, 2015 | Nabi 2
How to connect an asus transformer to a phillips picopix 2055 projector ?
you cant, directly at least... there are no drivers for android to run this projector. since it is only USB, you cannot convert the hdmi to usb...
you could use your computer as a middle man, without hdmi input on your pc there would be video lag and your better off just using your pc.
you could return the picopix you have and get the PPX2480 version, that is brighter and also has hdmi input which you could get a mini-hdmi to hdmi cable and use it directly.
hope that helps
Feb 28, 2013 | ASUS Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
How do I enable presentation mode on an XT2 tablet? I am in a meeting connecting a Dell Tablet XT2 to a Panasonic projector via vga cable and trying to use Fn8 to display the laptop screen. The setting...
You could be able to enable presentation mode by pressing the "settings" button on the bootom of your display, next to the power button and the "ctrl" and the rotate button. After you press that, your dell control point manager should pop up and then go to the tablet tab on the left and open it. after that, go to the display tab and you should see an option that allows you to turn your presentation mode on.
Nov 05, 2009 | Dell Latitude XT2 Tablet PC
My Epson EMP-S4 LCD projector does not display images from my Averatec C3500 laptop. It displays "No signal".. Do i have to press any keys before it would display? I suppose it would automatically project...
When you connect a data projector or external monitor to the external video port on the laptop, power up the data projector or external monitor first then the laptop. The video info will automatically divert to the data projector/external monitor automatically.
If you have already had powered up the laptop first, most laptops will allow you to toggle between the LCD screen and the external video port by pressing the Fn key plus one of the Function keys, this key will have a screen/laptop symbol.
Sep 08, 2009 | Averatec C3500 Tablet PC
Connecting to data projector
CONNECTING VIA VGA CABLE,RIGHT CLICK ON THE DESKTOP SELECT DISPLAY,
CONNECTING EXTERNAL DISPLAY,
MIRROR ON ALL DISPLAYS
WALLA AND BOB'S YOUR UNCLE
HOPE THAT SOLVES THE PROBLEM.
Jul 03, 2009 | Fujitsu Stylistic ST4110 Tablet PC
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Cant duplacate on extended monitor or on projector
Use your Q menu to select the "Internal and External" display. If this choice is not enabled on your Q menu, go to tablet settings and enable it there.
Feb 27, 2008 | Compaq tc1100 Tablet PC
Unable to connect to data projector
Hi. The Projector is recognized in Windows Enviroment as another Monitor. So right click on the Desktop = > Settings => Settings Tab => You'll find two monitors. Change to Number 2 then click ok. Now your Data from VGA Card will be redirected to your Projector Enjoy.
Feb 11, 2007 | Fujitsu Stylistic ST4110 Tablet PC
ASUS Eee Pad Transformer TF101A1 Tablet Computer Logo
62 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
