Question about Samsung HL-R4667W Compatible TV Lamp
SAMSUNG TV SERIAL NUMBERB10U3CEL800394F NEED TO FIND LAMP AND HOW MUCH DOES IT COST
  • 49 Answers
Samsung hl 6167w unit comes on no piture then shuts off
If the TV turns off then trys to come back on a few times then nothing, I suspect the lamp is not firing. The lamp part number is either on the left or right side of the TV on an orange and white sticker that says "Lamp code" Once you have the lamp code do a google search for that number for the lowest cost lamp. Be careful as some are lust the bulb itself and not the complete lamp assembly. I hope this helps : )
Jul 29, 2011 | Samsung HLN617W 61" Rear Projection HDTV
I HAVE A SAMSUNG DLP HLT5075SX/XAA AND IT STARS TO GET BRIGHTS LITLE DOT ALL OVER THE SCREEN WHAT IS THAT IST A PART THAT I NEED TO REPLACE?
Maybe your color wheel breaking up, if hit goes no picture or might be the lamp. If color wheel you can see it if you remove the back panel (UNPLUG TV FIRST) it's next to the lamp. Color wheel cost
Appox. $100 & If Blub Cost $75-$100 both can be bought online. Shop by you model #. If not sure what your doing call TV service Tech.
Good Luck!
Oct 09, 2010 | Samsung DLP HL-P5663W 56" TV
How much does a new lamp for a samsung tv sp46l5hx cost
Hi the lamp do you need is a BP96-00271C and I recommend for you to get the Phillips that will give you 6000 to 8000 lamp hours, I found your lam p at the links below please check them out
http://www.discount-merchant.com/BP96-00271C-Bulb-p/samsung-bp96-00271c-lamp.htm?click=52978
or also on Ebay
http://shop.ebay.com/i.html?_nkw=BP96-00271C&_sacat=0&_trksid=p3286.m270.l1313&_odkw=BP9600271C&_osacat=0
Good luck
Please rate this if it was helpful,as I do this for free
Regards
Jan 06, 2010 | Samsung HCN4226W 42" Rear Projection...
Samsung 56"TV lamp burned out
The lamp replacement is a do it yourself fix.
Feb 24, 2009 | Samsung DLP HL-P5663W 56" TV
My Optoma HDTV Model RD50 needs replacement of its internal lamp. Which model lamp is the correct one and how much does the lamp cost? Regards - Lee
Call Optoma technical support listed on the optomatv website. They will ask for the set serial number. Based on the serial number, they will tell you which replacement lamp is the correct model for your TV. (I found this out after ordering the wrong replacement lamp based simply on the model number of my TV and finding that it did not fit.)
Jan 11, 2009 | Optoma RD50 50" Rear Projection HDTV-Ready...
Samsung HL-S5087W shuts off.
the number is 3409-000178
should cost less then $5
Dec 29, 2008 | Samsung DLP HL-P5663W 56" TV
Hot to test tthe lamp bulb Samsung tv
bad lamp will cause 90% of problems you can take it out to see if it is broken filament is usually shattered
Oct 07, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung projection TV intermittent shut-down problem
OTHERWISE- THIS SET MAY HAVE THE DREADED 1500UF POWER CAPACITOR ISSUE WHICH ARE EASY TO SEE IF YOU CAN ACCESS THE MAIN POWER PC AND VISUALLY CHECK FOR 'POPPED' CAPACITORS ON THAT PC. JOE TV
Oct 04, 2007 | Samsung - Projection TV replacement lamp...
Samsung HL-R4667W Compatible TV Lamp Logo
69 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
