Question about Bosch Dishwashers
Classic bosch dishwasher not draining model no smu50e15au
Not draining , not resetting or resuming programme only 3 months old have turned off at power and waited
bigg t
  • 640 Answers
SOURCE: Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Posted on Jan 24, 2008
  • 249 Answers
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Posted on Feb 23, 2008
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
  • 457 Answers
SOURCE: the dishwasher is stuck in the drain cycle Bosch SHX46A
you have a leak,or the something has the float stuck in the open position. when water gets in the base the float raises and the uni automatically drain until the water is out of base. if this helps post a 4 thumbs up post
Posted on Feb 28, 2010
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
I need a wiring diagram for a Bosch SMU50E15AU dish washer. Thanks
You have posted this in the " Questions about Cars & Trucks " section . You need to post this question in
Dishwashers " . That being said , if you go to Yahoo.com , and put " Bosch SMU50E15AU dish washer wiring diagram " in the search bar , and hit enter , or click search web , you will get at least 8 printable images . ( Click on the image you want . When in opens up , click file in the very top left corner of your page if you are using the same operating system that I do . From the drop down menu , click print , or click print preview . Follow the prompts from their ) .
Good luck .
Dec 31, 2014 | Dishwashers
Bosch diswasher e15 light
Most likely it is the flood switch trigger causing the problem.
Many reasons for this but mainly it means there could be water leaked into the base of dishwasher where flood switch is located.
Or if you have Aquastop fitted in the water inlet hose then the hose might have kinked due to age or being pressed between cabinet wall and dishwasher. Turn power off to dishwasher at mains plug and pull it out. Check hoses. Tilt it about 20 degrees to one side on a towel and hold for about 10 secs. This should get the water out. Wait an hour or so to dry any moisture in the base and then plug back in and turn on. This should reset the E15 fault.
Apr 21, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch SMU50E15AU PROBLEM WITH FLOODING Does the
If dishwasher is flooding it is because the water inlet valve is not closing properly. Often they get stuck - you can replace the valve or take it apart and subject it to numerous on/off cycles after using wd 40 . That will loosen it up and save you some bucks!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 04, 2017 | Dishwashers
My bosch smu50e15AU dishwasher ,wont work ,my daughter used dishwashing liquid ,in it ,it bubbled out around the door ,now the only lights funtioning is the end & check water light and it will only...
My SMU50e15AU dishwasher keeps stopping and the check water light keeps coming on. I have checked all the hoses and none of them are kinked. There is a platsic plate beside the filter that im not sure what it is as there is no picture of this in the instructions
Feb 22, 2010 | Bosch Dishwashers
Purchased a Bosch SMU50E15AU dishwasher and think the water hose may be too short as the washer needs to be installed in the corner rather than directly next to the sink - read that due to the anti...
you will have to add drain hose to this type install . do not use a smaller size. 5/8 in ok and no sharp bends . ribed drain hose is good . whirlpool ext hose kit is a good one to use . this should not cause any problems. mm
Dec 02, 2009 | Dishwashers
I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Jul 26, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Jan 09, 2008 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
74 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
