Question about Garden
Need manual 14" mccullough electric chainsaw eager beaver
    Scholar:
  • 58 Answers
McCullough 14" Electric Chainsaw User Manual
(NOTE: This is also useful for the EagerBeaver Electric Chainsaw)
Online Manual:
http://www.manualagent.com/mcculloch/ms1415/users-manual
McCulloch MS1415 User Manual
PDF Manual to download:
https://libr2.com/get/mtd-ms1415-2409
Posted on May 28, 2015
plkruger
  • 32 Answers
SOURCE: Mcculloch chainsaw 2014 Eager ****** Model 00032-14
call 1-800-521-8559 select parts, ask them to email a owners manual to you, it's free, it's EZ
Posted on Feb 19, 2009
THIS WORKED FOR ME....I've had that problem for quite awhile. I finally decided to try to fix it. I took the chain and blade off, removed all the crud in there. Then I took a small air compressor and blew out the entire area so it was pretty clean. I started the saw at this point and gunned it some. The oil became noticible within a few seconds where it comes out at, above the outer chain blade bolt. Once I found the hole, I then drained the chain oil resevoir, and then using the air pump, blew out the hole from the blade area to the resevoir, leaving the oil cap OFF. Upon refilling the resevoir with a lighter oil (10 wt), I restarted the saw, and the flow was really coming. After the resevoir empties, I'll start using the regular bar-and-chain oil again, but it's pretty heavy, even though it says it is 30 wt.
JimBo
Posted on Apr 02, 2009
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
  • 19 Answers
SOURCE: need parts and manual
YES.
Posted on Apr 29, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCullough chainsaw series 3200 is leaking oil,
Operator Manuals for McCulloch are difficult to find and will not help with this problem unless you want a repair facility. You can try here:
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
You provided no model number; this one was given in a 3200 fuel problem I answered earlier. An IPL for the model you provided follows (this is actually a 3214, I have never found a 3200):
http://www.ordertree.com/modelinfo/MCC/11-600032-32-Mac-3214-06%2F93-IPL-211229/139.11-600032-32-Mac-3214-06%2F93-IPL-211229.1.59.1.html
It is the only 600032-32 here:
McCulloch IPLs (all)
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There is a less detailed print here:
Chainsaws 32cc-35cc
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
I know it is not plugged but this may also be helpful.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Posted on Mar 27, 2010
Garden Logo
712 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
