Question about Honeywell Ademco 6160 Alpha Keypad Vista 15p, 20p
Ademco security system still doesn't chime when press 9 key
System beeps, but when door opens no beep or chime. Please help! thanks!
  • eatgreatfood
    eatgreatfood Oct 24, 2012
    could the system be in a test mode?
  • 57 Answers
You need to enter your 4 digit code first. Make sure you do it half way quick.
Posted on Dec 27, 2012
4 Suggested Answers
  • 40 Answers
SOURCE: I can't get the system
Enter your code and the 9. This turns on chime mode. If it still does not chime the zone is not programmed for a entry exit or perimeter zone.
Posted on Jan 01, 2011
steve_hillin
  • 44 Answers
SOURCE: I have 3 ademco keypads on my system. The system
This means that the alarm panel's backup battery is either bad or not connected. These batteries provide power for the system in case of a power outage and are essential for a solid alarm system. Look inside your control panel box ( usually in the master bedroom closet ) and see if the battery connection is just off or if the battery is missing. If it is connected, it is probably too old and needs replacement. Contact your local alarm company and they can swap out your battery or provide one for you.
Posted on Mar 05, 2011
  • 58 Answers
SOURCE: alarm won't arm because of kitchen door. Don't
it sounds like your contact is messed up... deactivate that contact to see if all is well.
Posted on Dec 14, 2010
Honeywell ADEMCO 6150RF keypad sporadic constant beeping
It is trying to indicate a problem with zone 1. check it out.
Jul 25, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
The system randomly beeps
If it is wireless, then one or more of the switches need a new battery. I suggest replace them all and mark the date inside the box. I assume that there is no yellow triangle showing on the alarm panel. Triangle is for no phone connection.
May 28, 2017 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
My key pad is displaying not ready chime only
Not Ready means one or more of your zones is faulted. Pressing the * key on the keypad will display the zone or zones that are faulted. A faulted zone can be a door or window open, a motion detector "seeing" movement, and so on. It will also display a description of the zone. Chime means the chime feature on the keypad has been enabled. Any perimeter or entry/exit zone that faults will cause the keypad to ding three times. This can be turned off by entering your 4 digit code and pressing the 9 key. Doing so again will turn it back on. The link below is for the user manual for an Ademco Vista 20P panel.
Hope this helps.
http://panelguides.com/panel-guides?task=view.download&cid=1181
Mar 22, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
My alarm system makes a random beeping noise (like the chime noise you can set for when a door has been opened). What could be causing this to happen? Ademco Vista System
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 29, 2010 | Computers & Internet
Honeywell Ademco alarm panel beeped repeatedly for about a minute and now reads, "Chime BAT." How do I fix this problem?
Find the metal box (usually beige) housing the control panel and open it. The system backup battery is inside. Take it to Battery Warehouse or similar store and buy a new one to replace it.
While you're inside the control box, read the model number of your control panel. That can be useful for future questions.
Sep 12, 2010 | Honeywell 5804 Ademco Wireless Security...
Setting alarm to beep when doors are opened.
If it is a honeywell product enter your code then 9
Jan 12, 2010 | Honeywell 5804 Ademco Wireless Security...
Ademco security system every few min the carbon monoxide two beep
This could also be the ADT C.O. detector. they onlt last 5 Yrs. At that point they will beep every 5min nothing will display on keypad. Unit needs to be replaced.
Sep 13, 2009 | Honeywell 5804 Ademco Wireless Security...
Beeping at random times through the day
You are getting trouble beeps, every time you press status you delay the alarms for 4 hours then they begin again and beep every minute. You need to run a sensor test to find out which sensor has a problem. Open the panel, enter your code and press the test button, it will begin scrolling through the sensors. Activate each sensor until it stops, if one doesnt work it will keep asking you to activaate it. You probably have a dead battery in a sensor.
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
Goes off even when disarmed!
This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdf
It appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
Dec 26, 2008 | GE Security Simon 3 Wireless Home Security...
Honeywell Ademco 6160 Alpha Keypad Vista 15p, 20p Logo
349 people viewed this question
Top Honeywell Home Security Experts
Sean
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
