Question about Pioneer DV-C503 Multi-disc DVD Player
No sound playing DVDs
Hi, my DV-C503 has been working fine for many years, then inexplicably would not play sound for DVDs. I was using the optical Digital out connection, and swapped to the RCA plugs. That worked for a couple of weeks, now I don't get any sound at all. Any ideas of what I can try??
  • Kristian Howard Jun 03, 2007
    Thanks for the help. Although I don't like to admit it the problem was very simple. Somehow the settings on my amp was changed from the digital input being the DVD to the VCR. Your suggestion helped me dig though all the settings on the DVD and Amp to id the problem.
    Cheers
  • Anonymous Mar 26, 2014
    Since initial use the sound would occasionally drop out for no more than 1 second and then be fine. Upon try to fix that problem it hasn't worked since then
  • 76 Answers
Is it connected to 5.1 amp??.The first thing to try is to go to set up menu and change the audio o/p to pcm track.See if this works.What has more than likely happened is unit is set to dolby digital and should be on pcm track instead.If this doesnt work more than likely fault in unit but have seen very few audio problems with dvds.
Posted on May 26, 2007
Does not play dvds or cds
Laser lens may need cleaning by cue tip with rubbing alcohol, multiple times. Alcohol leaves residual must be diluted multiple times.
Sep 10, 2010 | Pioneer DV-C503 Multi-disc DVD Player
Pioneer model # DV-c503 will play DVD but does not play CD's anymore.
The problem could be dirt on the surface of the lens.
Use a dry cotton bud to clean the surface of the lens, this you have to do gently because the lens is fragile.
If otherwise you have to change the lens.
Try websites Shopjimmy.com,Ebay.com to buy parts for replacement..
May 28, 2010 | Pioneer DV-C503 Multi-disc DVD Player
SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
Aug 14, 2009 | Sony DVP-CX995V Multi-disc DVD Player
WILL MY DVD PLAY AREA 1 AND AREAV4 DVD'S?
Hi camonk2004,
It's interesting that your DVD player was purchased in Russia but plays Region 1 DVDs. Region 1 is North America. Does your Player also play Russian DVDs (region 5)? If so, then it has probably been modified to play DVDs from multiple regions.
Check the back side of the DVD player - the rear panel should have a Region number on it. If the region number is 1, then try playing a Region 5 DVD. If it reads the DVD, then the modification that was done in Russia will probably allow it to read any DVD. IF the Region 5 DVD won't play (or if it is ejected automatically), then your player's region control os still intact, and it will only play DVDs from the same region as the one listed on the rear panel of the player (or DVDs marked "ALL").
I hope this helps - please let me know if I can be of any further assistance.
Kind Regards,
H2H
Dec 15, 2008 | Pioneer DV-U7 DVD Player
Surround sound not working properly
this isnt a solution to your problem but i have a suggestion. I see this problem has been posted a couple days now and i think that because your problem looks like it involves more stereo equipment rather than the xbox 360 console. i think you would get a better answer actually a soltuion if you posted this in the stereo section.
Dec 22, 2007 | Microsoft Xbox 360 Console
Will play dvds but not cds
your DVDneeds to be adjusted take out the tray turn over the lens there are two shiney screws to the bottom of the lens the one to the right is for dvd and the one to the left is for cd turn to adjust. good luck.
Apr 02, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Movie Freezing
Sounds like youe unit is getting tired my freind. they dont make em like they used to. The unit most likly needs a tracking or focus servo alighnment, but to put it on a bench, and have a tech adjust the alighnments, will most likly exceed the cost of a new unit. The laser could also be getting weak, and the replacement optical assemblies for this unit alone cost about 60 bucks. Then you have labor and alighnment cost, as you don't just throw in an optical pickup assembly and it works. Good Luck Please, do not forget to rate this thread.
Dec 10, 2006 | Toshiba SD-V392 DVD Player/VCR
Pioneer DV-C503 Multi-disc DVD Player Logo
161 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
