Question about Lexmark JetPrinter X1185 All-In-One InkJet
Paper feed isn't feeding properly Lexmark X2350
It was working.............then was put in the loft for some time.
Now the paper feed just screws the paper up and doesn't paper it through the printer in order to print.
    President:
  • 1,990 Answers
Welcome to Fixya! You can get some Compressed air and blow out the Rollers and Check from Underneath where the Paper feeds out to. Could be stuff in there clogging it up.
Posted on Jan 02, 2009
  • Lexmark Master
  • 13,433 Answers
Take all the paper out and inspect the printer for any paper jams or dirt inside, if possible open the back cover to inspect the internals.
Clean the rollers and the printer in general inside.
insert 5 pages of paper, make sure they are a little loose, not too thight and try to print something again.
Paper will not feed
Hi, maybe there is still a little bit of jammed inside that you can\'t see. Try to see if there is and clean it. If you\'re sure there is no paper jam whatsoever, then there is a conflict with your feeding sensors or your cartridge isn\'t properly installed.
kind regards
Apr 17, 2013 | Lexmark X4650 InkJet Printer
Lexmark x2350 all in one. paper will not feed
One of the leading causes of paper not feeding issues is some sort of foreign objects or debris falling into the paper feed system. Remove the sheets of paper. Grab a flashlight and look into the feeder for any debris. If you are willing and capable, carefully lift the printer upside down. Any debris should just freely roll out from the feeder.
Apr 12, 2011 | Lexmark X2350 All-In-One InkJet Printer
Hi, My Lexmark 2350 is not feeding paper through. It pulls on the right hand side but doesn't feed through and then says there's not paper in the tray. Any suggestions? Karla
Try to remove the sheets of paper from the feeder. Grab a flashlight and take a look into the feeder for any foreign objects that might have accidentally fallen into it. If none, unplug and replug your printer into your power source to reset it. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
Mar 06, 2011 | Lexmark X2350 All-In-One InkJet Printer
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
SAME PROBLEM LEXMARK X2350 STARTS FEED PAPER AND PRINTER HEAD MOVES AS PRINTING BUT WILL NOT FEED PAPER WHILE PRINTING? ARE THERE 2 FEEDERS IN THIS PRINTER? HOW TO FIX?
transfer roller that starts the paper and feed that feed the paper. have you had a paper jam and torn a piece of paper off inside the feed mech? i dont remember if this one feeds off the motor or a belt. either way you would have to disasemble the printer to determine where the problem lies. might be more econimical to replace the printer.
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x2350 will not work Machine states ''paper blockage''when there is no paper in and refuses to take paper there is somepaper in Please advise if you can.K Milson
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Dec 03, 2008 | Lexmark Office Equipment & Supplies
Lexmark X2350 Paper Feed Troubleshooting
Check to make sure there arent any stray paper fragments in teh paper path. Also try taking a pencil eraser to the paper pinch rollers GENTLY.
Mar 26, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 paperjam/top cover sensor problems
I thought I got all FOD out of my printer, till I turned it up side down.
Pencils apparently find the x2350 very comfortable.
Nov 30, 2007 | Lexmark X2350 All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
