Question about Kenmore Refrigerators
Leak from Kenmore Compact Refrigerator, Model 461.95882
I am noticing water that seems to be leaking from the base of our compact refrigerator (model 461.95882) What might be the problem?
  • 249 Answers
SOURCE: refrigerator will not cool
there is a fault in compressor motor the clicking is the overload cutting off,If its a relay on the motor its worth repairing,If its the whole motor it would be too costly,I know
its not what you want to hear,but thats the size of it.the relay is in a black plastic box on the motor itself,I hope its that
Posted on Dec 16, 2007
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
aasc
  • 1606 Answers
SOURCE: water leaks from top mounted freezer area into the refrigerator
Remove the food from the freezer and the icemaker if equiped . Remove the air tower at the rear of the freezer section and remove the rear panel inside the freezer . Using a hair dryer to the drip pan , below the coils ( probably ice ) , starting at the center , defrost until you see the drain hole . Keep defrosting the hole ( hot water helps ) until water starts to flow down . Using a short piece of hose , insert it into the drain hole and blow . This should blow out any debris inside the drain hole . I would use a short piece of solid ALUMINUM wire ( 14-16 guage about 8 " long ) striped of all insulation , and insert it into the hole as far as possible , without any force . Wrap the other end about 1--1 1/2 turns around the black tube ( defrost heater ) above the hole . When the heater comes on , heat will transfer to the aluminum wire and keep the drain from freezing up again . Reasemble back panel , air tower , and , icemaker . Reinstall the food and its FIXYA'd .
Posted on Sep 02, 2009
Testimonial: "Thanks for the suggestion. "
  • 24 Answers
SOURCE: Recharge Refrigerant 134A into Fridge
get a pericing valve from your local appliance parts store 25 inch and put it on the small little what i like to call pig tail make sure your pluged up and running when you do this .go get a can of 134a from autoparts store best one is advance autoparts get a car ac switch over kit from r12 to 134a and in it will be a fitting that will fit your pircing valve then read instructions from their .GOOD LUCK !!!!
Posted on Oct 12, 2009
SOURCE: Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Posted on Jun 04, 2010
Can a compact refridgerator be recharged
Yes, but you have to understand that if it needs recharged, it has a leak and must be found, repaired, evacuated then properly recharged. Most compact reefers only hold a few ounces of refrigerant, so it does not take much of a leak to affect its ability to cool....Your issue could be something other than refrigerant if its just not cooling.
Jul 14, 2014 | GE SFR03BAZBB 3.2 Cu. Ft. Compact...
Kemore compact refrigerator
It sounds like the temperature control is inoperative. They aren't too hard to replace, and $150 seems high for a control, but If replacing it is not something you or a friend could do, then a new refrigerator seems like the best choice for you.
Nothing lasts forever, and if you have already got 15 years of service out of it, then it would be a bad gamble to put that much money in a repair. I'd buy a new one and sell your old one on Craigslist to someone willing to fix it. You may find that you can go a lot longer than two weeks between defrosts during drier parts of the year, and the 'fridge isn't going to care if you go a lot longer than you think is necessary between defrost cycles.
Apr 18, 2014 | Kenmore 91495 Compact Refrigerator
Refrigerator will not cool down
If the unit does not cool down at all, then you might have a refrigerant leak and be low on gas. Locate the leak, fix, and refill to manufacturer's specs.
Jan 18, 2014 | Kenmore 4.6 Cu. Ft. Compact Refrigerator...
Kenmore 1.8 cu. ft. Compact Refrigerator stopped running and won't turn back on?
It is really hard to say why it shut down, but my best advice is to make a service appt. asap to have the problem looked at.
Feb 15, 2012 | Kenmore Refrigerators
Mar 18, 2010 | Refrigerators
Water build up at bottom of Kenmore Compact Fridge
Problem on your Refrigerator bypass plastic water sypply pipe.May be it was block dust,so you can clean it then water thorough the tank.
Mar 15, 2010 | Kenmore 4.9 cu. ft. Compact Refrigerator
Compact Refrigerator stop cooling, I am out of ideas.
Good day,
If you hear the compressor running, then the overload and relay are O.K. It can be one of three things.
1. Leak developed in system.
2. Restriction internal in the refrigerator sealed system.
3. Valves in compressor failed, which would not provide any pumping action for the refrigerant.
None of these items are practical repairs on a compact. But if it's under warranty (under 5 years old), check with the selling dealer for warranty claim.
P.S. Does not apply if coils were punctured.
Thank you for using FixYa
Jan 16, 2010 | GE GMR02BAN Compact Refrigerator
New kemore compact won't get cold, motor runs ok but won't turn off
If it's new (under 5 years of age) it is under factory warranty, if it's a sealed system failure. Bad compressor, refrigerant leaks, or restrictions in the connecting tubing.
Contact Sears with complete model and serial number.
Nov 08, 2009 | Kenmore Stainless Steel Compact...
Refrigerator is NOT refrigerating anything.
Get a technician, there might be a gas leak or compressr out of order
Aug 28, 2009 | Refrigerators
Refrigerators Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
