Question about Refrigerators
Fridge so noisy constant - Refrigerators
One of the known proplems of noise in refrigration is the fan.try checking the fan and oil it. the compressor cannot be noisy.u can start by uncrewing the power line to the fan and see whether the noise is still there
njeru .embu -kenya
Posted on Oct 24, 2012
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
Posted on Dec 20, 2009
Noisy compressor on fridge freezer
does it always make that hum noise or just when adjusting temp
Aug 18, 2012 | Kenmore Refrigerators
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Noisy Aga fridge
where is the noise? inside or outside? inside maybe the evaporator fan motor. hitting somethig> wire . get a tech to double check not dangerous. outside. noise compressor dont replace. have to live like that or replace the whole fridge. or condenser fan motor. call atech for replaced
Mar 30, 2010 | Refrigerators
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Noisy Kenmore Fridge
remove rear panel. make sure compressor is not loose. is noise inside refrigerator or outside at bottom rear?
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Noisy Fridge !!
is the fridge on a level and solid surface ?? hope this helps regards Jim
May 10, 2009 | Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Inglis Refrigerator causes disturbances in tv, computer, etc.
i would say that its on its way out if its causing so many issues.if its running too often then it will cause the compressor to over heat eventually
Jan 19, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
