Question about Canon S 750 InkJet Printer
Canon s750 flashes orange light 4 times then green
SOURCE: CANON IP 1880
i need install canon ip1880.. how?
Posted on Oct 05, 2008
SOURCE: canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Posted on Apr 24, 2009
envision507
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
cene765
  • 787 Answers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
Posted on Oct 19, 2009
cene765
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
HI I have a canon s750 printer which is flashing 7 orange lights and one long green................it will not print........can u help? Thanks Alistair
7 flashes is saying the ink absorber is full. You need a shop to replace the absorbers which cover the entire bottom of the printer and have a shop reset the counter.
Nov 05, 2009 | Office Equipment & Supplies
7 orange flashes and 1 green?
That error says the printhead is bad, it is QY6-0041-000, and costs around $60.00. That printhead is soon to be discontinued by Canon and you'll need a new printer.
Oct 29, 2009 | Office Equipment & Supplies
3. Release RESUME
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Printer is not responding
This is the error light page from the S520. Not sure about this, but probably the same on the S530. 8 Blinks means replace the ink absorber and reset the counter. I think the ink absorber can be gotten at from the bottom, BUT NOT SURE. Try this at your own risk!
7.1 Service Mode Operation
1) With the printer turned off, hold down the RESUME button and press the POWER
button (the green indicator lights and the desired service function can be selected).
2) While holding down the POWER button, let go of the RESUME button before pressing
the RESUME button again twice in succession. Then let go of both RESUME and
POWER buttons.
(At each press of the RESUME button, the indicator toggles between orange and
green.)
3) During printer initialization, the green indicator blinks. When the green indicator
stops blinking and remains on, press the RESUME button the specified number of
times to execute the desired service function, as listed below.
green.)
Press Indicator Function
0 times Green Power off (Even if there is no print head mounted, the
carriage will return to the home position and lock.)
1 time Orange Service/factory test printout (Including ink sensor check)
2 times Green EEPROM information printout
3 times Orange EEPROM initialization
4 times Green Clears the waste-ink counter (S750/S520)
Waste-ink counter settings (S900/820) (See page 2-34)
5 times Orange Destination (model) setting
After reaching this service function, press the RESUME
button the number of times specified below to set the
destination.
Setting
0 times BJ F900 BJ F890
1 times S900 S820 BJ F700 BJ F500
2 times BJ F890PD S750 S520
3 times S820D
Note: pressing more than 3 times has no effect.
6 times Returns to the function select stage (S750/520)
6~9 times Not used for servicing (S900/820)
More than Green Returns to the function select stage (S900/820)
10 times
4) After selecting a service function, press the POWER button. The green indicator
lights and the service function will be executed. (After each function is executed, the
printer returns to the service function select stage.)
READ THIS CAREFULLY !
Larry
Nov 30, 2008 | Canon S 530D InkJet Printer
Canon S520 blinks 7 times yellow then once green over and over, won't print
Read the info on the link below:
Solutions for flashing lights Issue: Alarm / Power light flashes orange 7 times consecutively (Print head error)
1. Reseat the print head S520 / S750 2. The Print Head may need replacing - S520 3. The S520 may require repair
spacer.gif http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=231&modelid=6611
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | Office Equipment & Supplies
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Canon S 750 InkJet Printer Logo
106 people viewed this question
old marine
old marine
