Question about Cameras
Camera has lens control error
On starting up a lens control error comes up on screen and unable to solve the problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Posted on Oct 24, 2012
t00nz
  • 4738 Answers
SOURCE: lens error
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
SOURCE: Lens Error, Restart
Nikon System error help????
Posted on Sep 24, 2008
SOURCE: camera olympus error D: 5f08 5e02
The error message (D: 5e02) means that your lens is dying / dead. It just happened to mine and I was told that it could be repaired, but it would cost as much as a new camera. I've only had mine 2 years and I've been really careful with it, so I'm a bit annoyed, but I have used it a lot!
Posted on Jan 05, 2009
zohail
  • 1223 Answers
SOURCE: The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
Posted on May 28, 2009
SOURCE: Sanyo VPC-E760 Lens not closing
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Posted on Jul 05, 2009
When we turn on our Sanyo VPC E1090 digital camera the lens does not appear to come out completely & we get an "lens error 0x0311" message on the screen then it turns off. WHAT IS WRONG!! ...
If lens does not appear to come out completely and camera gives error that means lens mechanism got broken internally and lens assembly will be replaced to solve the issue.
Lens replacement is not user level repair and local camera repair shop[ will do this job for you if camera is out of warranty.
Thanks.
May 28, 2011 | Sanyo VPCE1090 Digital Camera
D90 - unable to shoot photo & remove lens from camera body
you must try to remove the lens that lens have some electric contacts and if you set the lens in wrong position that contacts give to the camera some error message
Feb 28, 2010 | Nikon D90 Digital Camera with 18-105mm...
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
Nikon coolpix 2200 zoom problem
I was having a "Lens Error" with my Nikon Coolpix S210 camera and this websites' tips fixed my camera.
Aug 16, 2009 | Nikon Coolpix 2200 Digital Camera
I have had my camera for about 4-5 years. It has worked great. lately it has started to act weird. when I turn it on the screen says access and wont let me take a picture. then after a few minutes the...
Go to camera Menu and select Initialize, OK.
Camera will turn on itself, if problem still exist, tap camera gently and turn On again to solve lens access problem.
Memory stick error can be solved by formatting it through Format menu in camera. Use another memory stick in camera to make sure that camera is OK.
Aug 12, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Lens Error
I solved the problem with a recommendation Rob posted here on FixYa. Some air pressure blown around the lens and it worked. Thanks, Rob. You're my hero! I almost sent the camera in for repair.
Apr 08, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
E 18 problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 09, 2008 | Canon PowerShot A520 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 13, 2007 | Vivitar ViviCam 4345 Digital Camera
Lens Error
Firmware doesn't solve lens errors. that can only be solved by sending into repairs. Give them a call at 800-706-2534 and then keep choosing option 1.
Jan 02, 2007 | Casio QV-R3 Digital Camera
Cameras Logo
56 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
