Wiring diagrams for percival gas heaters
Percival Heaters are no longer manufactured
  • 92 Answers
SOURCE: 8 foot heaters in tandem
you should not wire heaters in series in less you know how to size wire and the amps that a wire can carry.you are flirting with fire
Posted on Feb 24, 2009
nenalex2002
  • 134 Answers
SOURCE: I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Posted on Mar 22, 2009
appman67
  • 33 Answers
SOURCE: Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
Posted on May 03, 2009
  • 118 Answers
SOURCE: no i didn't. I need instructions for wiring a
you have baclk and red wire supply and a black and red wire to load (baseboard).
your switch will have 2 black and 2 red.
connect blk supply to 1 black on switch ( it doesn't matter which one)
connect red supply to 1 red on switch
then
connect black from baseboard to black switch
connect red from baseboard to red switch
if multiple baseboards that have several loads at thermostat then just connect baseboard blacks together and reds together before connecting at switch.
Posted on Oct 26, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: wwiring baseboard heaters
http://partner.dimplex.com/files/domain4103/7207610100rev00.pdf
Posted on Dec 29, 2009
Forgot my apple id, and my password for my apple ipad
forgot my apple id and my password, the email address is no longer my email, my new email is toppy65@ymail.com but I had find my ipad turned on how can I make a new apple id without knowing the apple id I had on it or the passwork
Nov 11, 2013 | HP iPAQ hw6515 Pocket PC
Percival-alway@virgin-broadband.com.au
Please don't put passwords into Fixya posts! Ever heard of identity theft? Edit it out please. For some reason I can't and a Moderator, I should be able to!!
You have your email address written wrongly. There is no hyphen between virgin and broadband.
Percival-alway@virginbroadband.com.au
Details are here
https://community.virginmobile.com.au/t5/Support-Articles/Login-details-for-Virgin-Broadband/ta-p/144
Apr 04, 2013 | Motorola Mobility V360 Cellular Phone
Wiring diagram on whirlpool gas water heater
Whirlpool is AO Smith tank-type heater.
Year, model, type of heater not known.
So add a comment and then expert can look up the manual.
You probably have power vent, or dampered water heater, otherwise the only wiring would be for thermopile, thermal reset, and igniter.
Power vent, or dampered, of flow control water heaters plug into outlet, and wires from gas control run to the various components.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Review-AO-Smith-Effex-water-heater.html
Don't forget to add comment and include model number that shows on label located side of tank.
Sep 21, 2012 | Whirlpool 6th Sense 40-Gallon 6-Year Tall...
Require a wiring diagram for a raypak gemini 3 gas pool heaters
Have you tried http://www.raypak.com/productDocumentSearch.aspx
Needs a model number...but I looked at some of the pdf manuals there and they do have wiring diagrams in them
Dec 03, 2011 | Pool & Spa
How to change the filter and line from pump to filter
Should not change all the fuel line .Cut the bad line fuel and Measure the required distance . and take with you the bad line fuel to Advance Auto Parts . and ask him for new line and fuel filter and Link to connect the line fuel together , make sure no leak . good luck .
Nov 21, 2011 | Chevrolet Lumina Cars & Trucks
I need a diagram for a parallel (?) 220 circuit using 10/3 wiring for 3 wall heaters and 3 different t-stats for 3 rooms
are you sure 10-3 wire is big enought to handle 3 heaters on one circuit? I would call that into question before going forward.
Apr 23, 2010 | Cadet Manufacturing C152 Com-Pak Plus...
Wires not connected to gas valve need wiring diagram for Cozy wall vent heater
I think you mean a milli-volt system. I went to the cozy heaters website and found the wiring diagram in an owners manual for a similar unit, a W355. I bet the wiring diagram will work for your.
Dec 10, 2009 | Cozy (W352E) Heater
Wire diagram doesnt match what was there
then it may have been wired incorrectly. or you are looking at a diagram that is for or without a thermastat. I STRONGLY reccommend that you follow the manufactures diagram.
Sep 19, 2009 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
