Question about Texas Instruments TI-83 Plus Calculator
Clearing TI-83 screen
Shouldn't the CLEAR key do just that, clear the screen of all numbers, data, etc. and return the cursor to a home position?
  • 4 Answers
The CLEAR key will do that for most functions. However, if you are in some modes, like MATRIX>EDIT or STAT>EDIT, you will have to press 2nd+QUIT (the MODE button) to get back to a the regular screen, which you can then clear with the CLEAR key.
Posted on Jan 03, 2009
I get black "lines" going across the screen when i hit the graph button. It will graph also,but you can barely see the graph. Help pleae.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect first.
1. Try a new set of AAA batteries.
2. Adjust the contrast by pressing and releasing the 2nd key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message.
4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Jun 04, 2013 | Texas Instruments TI-83 Plus Calculator
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
How do i reset my ti-83 plus
Press [2nd][+] to access (MEM)ory management. Select [7:Reset][1:All Ram][2:Reset].
Calculator answers "Ram Cleared". Press [CLEAR] key or any key to get the main calculator screen.
By resetting the Ram you will lose any information that is not archived (data in lists, defined functions, graphs, etc.)
Mar 09, 2010 | Texas Instruments TI-83 Plus Calculator
Ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Oct 09, 2009 | Texas Instruments TI-83 Plus Silver...
Random symbols and/or dots all over the screen, cursor in middle of screen an turns off randomly
1. Press [2nd][QUIT] to interrupt any program that may be hung in memory such as games run under MirageOS.
2. Clear the screen by pressing [CLEAR].
3. Reset memory [2nd][MEM][7:Reset][1:All Ram][2:RESET] [ENTER]. ram cleared appears on screen.
4. Press [CLEAR] to go to Home screen.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-83 Plus Calculator
If the numbers are not registering on the screen what is the probability that the calculator is conmpletely busted????
1.Turn calculator on and adjust screen contrast
Press [2nd] , release
Press [UPArrow] release
Repeated the two steps until contrast is adequate.
2. An application may be running.
Press [ON] key several times to interrupt and [CLEAR] Screceen
3. Reset memory
[2nd][MEM][7:Reset][1:All Ram][2:Reset] then [Clear] screen. The blinking cursor should come back on.
Hope it helps. .
Aug 05, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Silver Edition problem
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
Calculator will not come on
I have the same problem with the calc not responding to removing one batt and reinstalling while holding clear, etc. My fix is to hook up wires to the battery leads and plug the wire into a 120 volt outlet. Watch it light up, but do NOT breath the smoke as it is extremely toxic. ;-) lkw
Aug 25, 2006 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
282 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
