Question about IBM ThinkPad T41 Notebook
Reset cmos I have a cmos ram test fail and need to try to reset cmos
  • IBM Master
  • 32,281 Answers
Removing the CMOS battery for 15 mins will reset the CMOS.
The CMOS failure most likely is caused by a flay CMOS battery. replace the CMOS battery will fix this problem.
Posted on Oct 25, 2012
Just installed GA-X58A-UD3R board with brand new cpu cant get to boot. It starts to all lights come in then times out and resets itself. It will stay running if I hold in cmos button but still no video...
Try the following quick checks:
- reseat RAM and ensure using blue slots first before the gray DIMM slots, also do #2
- make sure CPU fan working correctly (2/3 pins are much more common now) and reporting status
Then try this, failing the others:
- test CPU temperature, 95 degrees Celsius is usually auto shut-off for AMD CPUs
EDIT: 5/20/2015 -- My above answer is woefully incomplete, for which I apologize.
In 2004 one of my clients was having almost the exact same problem as you have described in terms of symptoms, except they were using a . After doing my best to troubleshoot the problem, and failing to find a solution, my client exchanged the DOA motherboard for another Soyo Dragon II.
That motherboard had the exact same problem, and I was out of ideas, so I took the whole darn rig to my Mentor just down the street. Within only a few minutes he pinpointed the problem as being faulty capacitors on the motherboard, which he determined by comparing voltage and amperage readouts to what the motherboard manual listed -- http://www.NewEgg.com responded promptly with the unfortunate news that the entire production run of these Dragon II motherboards had bad capacitors (they then, free of charge, shipped my client via overnight air a similarly eComStation compatible motherboard that was at least 3 rungs up the ladder from the Dragon II).
I strongly suspect it is an issue caused by your motherboard, more specifically its DualBIOS feature somehow reporting false positives. This link gives you the run-down on its specifications and reviews from other users with essentially the same problem: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Mar 15, 2015 | Computers & Internet
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
1-3-3-1 beep at boot on toshiba satellite
If the Toshiba satellite uses the Phoenix BIOS, then the 1-3-3-1 beep code indicates a memory problem. The specific problem the BIOS saw on the self-test is 28 Autosize DRAM.
It could be a problem with the CMOS battery. You can try replacing this coin battery. You can also try resetting the CMOS. For some computers, you can do this by removing the battery for 20-30 minutes. Other computers will have a CMOS jumper that you can use to reset the machine. I'd need the model number to check the CMOS reset.
More likely one or more of your RAM is incompatible or damaged or the motherboard RAM slots are damaged. If you have two memory sticks, then if they aren't the same speed or type, this error can occur. Remove the RAM and test one stick at a time. If you recently added memory or otherwise upgraded your RAM, test the old memory and the new separately.
Sometimes, you can accidently get the wrong memory. Some computers can only support RAM with memory modules on one side of the memory stick. Newer memory often has memory modules on both sides. (This applies only if you recently upgraded the memory. You should use a memory configuration tool to check the supported memory for your machine. Each memory manufacturer has one for their memory.)
If this error occurs with the original memory or each memory stick separately, you will need to test the memory in another computer or get new memory to test in your Toshiba. That will determine if the memory was bad or if the motherboard is damaged.
If you add a comment with your computer's model number and the details of your memory for the system, I may be able to provide more specific suggestions.
I hope this helps.
Aug 07, 2011 | Computers & Internet
Intel D102GGC2 Motherboard beep is there if removed ram but when i cennect with power no display i changed vga card, power supply also and processer pls help
Please remove the cmos battery and reset the cmos by change the jumper to reset.
Then remove the motherboard from the cpu cabin and try to test outside TO AVOID any grounding issues.
Hope this helps to you..
Jul 21, 2011 | Intel D102GGC2 Motherboard
No video with or without a new video card on an asrock p4i65gv motherboard
So you can no onboard video when using the onboard connection right? and no video using an external video card also right? In this case, the promblem lay with the motherboard/ram/cpu and not with your video card. Try resetting the bios via taking out your cmos battery or shorting the cmos pin to see if a miracle would happen and the system would post. If not and if you have another board with compatible hardware, then you can try testing out the cpu, the rams. If you hear beeps when starting up the system, try to take note of it and look up on the internet via what bios make it is, and decode the beep error for what is wrong. If you don't her any beep, the other way only to know what is wrong is having another compatible board to test your cpu/ram, or make sure the ram and cpu you are using is supported by the asrock motherboard. If you do have another board to test your cpu/ram and even the video card, and they work, then your motherboard is scrap and needs to be replaced.
Jan 26, 2011 | Asrock P4i65G Motherboard
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Cannot boot up
maybe you must reset the bios in the motherboard. try to open your system then look for a 3 pin in the motherboard near in the CMOS battery.. it has a number 1,2 and 3 it is called jumper settings.... try to put the pin in number 2 and 3 then w8 after 10 seconds then gput it back to 1 and 2 in try to boot up.. ^^ i wish this could be help.. ^^
Feb 06, 2009 | Albatron Nforce2 (KX18D PRO II)...
IBM Thinkcentre A51
please check the system board if there is any bloated capacitor,and also try to take out the cmos battery reset the cmos and try to boot,if it fails,its system board.replacement needed
Nov 21, 2008 | IBM ThinkCentre A51 PC Desktop
A8n32-SLi Deluxe - Will not boot
your bios can be reset to defaults by removing the CMOS battery, then moving the little blue jumper to the right of it from the 1-2 pins to the 2-3 pins fpr 10 seconds, then place it back onto the 1-2 pins, replace the battery and boot as usual.
Nov 15, 2008 | ASUS A8N32-SLI Deluxe Motherboard
Switch on back of PSU needs to be turned off and on after restarting Windows XP to successfully POST
If there is an update for your bios I would suggest applying it after you get the system working properly again. It won't hurt to reset the cmos either, also be sure the smaller Ram is in slot A, some motherboards need it this way. Also are your RAM matched, I>E> both high/low density. Running with minimum RAM will rule out some of these questions so disregard any impertanant suggestions, and let us know how you come along.
Feb 12, 2008 | Foxconn 6150BK8MC-KRSH Motherboard
IBM ThinkPad T41 Notebook Logo
1,076 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
