Question about Refrigerators
My kitchenaid dishwasher will shut off approximately 10-15 minutes after it begins, no matter what setting it is put on. Any suggestions?
We bought this dishwasher about a year ago and haven't had any major issues with it. It cleans good and was very quiet. We have had to replace the brackets on the top rack because one of them broke, but that was no big deal. Now, no matter what setting it is put on, it will not finish the cycle. I have tried to press high-temp, heat dry, heat dry twice, like I've read on one of the blogs and also turning the breaker off and back on, nothing is helping. It's and under-counter dishwasher, the number inside to refer to is W103111238, I don't know if that helps. Thanks for any advice.
peyton32034
  • 410 Answers
SOURCE: kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Posted on Dec 18, 2007
refritech08
  • 149 Answers
SOURCE: fridge is too cold
do a test put the fridge on 1 or 2 (the warmest settings) if you don't see that it turns off you have a defective thermostat. there pretty easy to buy and to install if you need assistance just feel free to e-mail me @ hvac.tech7872pr@gmail.com
Posted on Jun 15, 2008
SOURCE: Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
Posted on Jul 13, 2008
  • 1218 Answers
SOURCE: I have a SubZero 690, approx 11 years old. It has
Good day,
5 months surely doesn't point to the machine. I would check the wiring and replace the breaker and retest.
Breakers can become weak from age. They are by definition a heat operated device. Due to just happenstance it is posssible for both compressors to try to start at exactly the same time.
That would push the demand fairly high.
As well, usually unknown, breakers are rated at 80% of their value for continious duty. I.E. 20 amp breaker can maintain a load of 16 amps under continious load.
One caveat. The condenser coils need to be cleaned on an annual basis. To vacuum them is a poor solution. They need to be blown out with compressed air or a quality shop vac. Ugly but extremely important on Sub Zero's.
Posted on Aug 19, 2010
Testimonial: "Thanks. Just what I was looking for!!!"
heatman101
  • 43501 Answers
SOURCE: Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 03, 2010
My kitchenaid DW kudc101xwho will not stay on. Runs a few min and shuts off. Is this the control panel or the timer?
May be this is the reasons.
a) May be your door latch is opening due to pressure inside the dishwasher. The door latch opens and the dishwasher will stop. Quite common problem on KITCHENAID. KitchenAid door is a heavier door compared to sister product WHIRLPOOL. If door latch problem then has to change the door lock along with the top latch.
Sep 25, 2014 | KitchenAid Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
TAKES A LONG TIME,
Takes a long time to what? If the entire cycle seems to take forever, one suggestion is to make sure your hot water heater is turned up. Most dishwashers requires the water to be a minimum of 120 degrees before the timer will begin. If you are using a Sani-Wash cycle, then the water need to heat up to 165 degrees. The heater can only heat the water 1 degree per minute, so if the water coming in to the dishwasher is only 100 degrees, it will take an additional 65 minutes before it will even start the cycle. You can also make sure you get the water at the sink hot before you start the dishwasher, this will ensure the hottest water is going in (only fills for 90 seconds).
Jul 30, 2010 | KitchenAid KUDR01TJ Dishwasher
I have a GE GLD5860L15SS Quiet Power 2 dishwasher. Lately, no matter what cycle its on, it will start for approximately 2 minutes, and then shut off. The dishes are wet, so I know water is coming out. How...
Sounds like a motor overload switch. You may have a bind on your motor or a clogged water pump. Try removing the kick plate and take a look underneath. You'd be amazed at what can end up under a dishwasher.
Mar 07, 2010 | GE 24 in. GLD5860LSS Stainless Still...
BUZZING SOUND WHEN RUNNING
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
Mar 16, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
////////////////////my kitchenaid dishwasher lights are flashing
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
