Question about Check Point Network Adapter
Sony tv model kv-xa29m20a sound intermittent
Sound comes and goes. sometimes not controllable
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
MY tv was hit by lightning its a sony trinitron model kv-XA29M20A
this may sound daft but ANY electronic equipment hit by lightening should be thrown away. it is not worth even trying to repair it.
try claiming on your home insurance policy.
Jun 24, 2009 | Televison & Video
Intermittent sound problem on sony trinitron
take it back to repair shop/ bad fault not looking good
Dec 10, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Son Trunitron
You have bad solder connections on the vertical output integrated circuit. Since now nothing helps either the solder connections have become very bad OR the vertical output integrated circuit finally failed from the intermittent condition.
Feb 27, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Mar 25, 2006 | Sony KV-32S26 32" TV
Check Point Network Adapter Logo
59 people viewed this question
Top Check Point Computers & Internet Experts
DROPNDEAL
DROPNDEAL
Laxman Bisht
Laxman Bisht
Gil Shultz
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
