Question about Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V Automatic Submersible Sump Pump, 8' Power Cord
What kind of oil is in the little giant pump - Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V Automatic Submersible Sump Pump, 8' Power Cord
3 Suggested Answers
SOURCE: Little Giant Condensate VCMA-15UL pump. Pumping when the float was down.
new pump
Posted on Nov 12, 2012
  • 170 Answers
Little Giants are noted for having faulty float switch problems----even the new ones----a major HVAC company I worked for discontinued using them because of this----they remove 1 to 2 years worth of installed pumps and substituted another to because of warranty no heat/ac/flooded floors call backs and returned all of them to the mfg including all of the stock they had---for life of me I can't remember the name of the new ones---when the float failed it would shut down the furnace or ac and usually flood the floor by NOT pumping --- being a service warranty----the pump was replaced not repaired---they probably could of been repaired though with another float switch such as what could be done with yours---that's all I got--good luck
Posted on Mar 03, 2015
How to disassemble Little giant pump model#psm006?
thats why i like the little giant pumps they are put together with phillips screws not glued like them other guys , i do suggest that if you dissasemble pump and water has gotten inside , replace it not just seal it up and go , wont last long as that means the pump shaft seal has leaked , ther e has been a few folks that add dietary mineral oil to the inside , for use in very deep ponds (over 3 feet) they believe that helps keep the water out
Jun 11, 2014 | Little Giant Submersible Fountain Pump
Littlle giant pump model 2e-ndvr what oil goes inside this pump
"pump oil" usually is a fire redardant mineral type , ive seen good uses of dietary mineral oil avail at local phamacy , but is sort of pricey if filling a total pump up with it (allways allow for heat expansion)
Apr 01, 2013 | Little Giant 5-MSP Water Wizard...
WHAT KIND OF OIL , AND HOW MUCH ,GOES INTO A LITTLE GIANT 5-MSP SUMP PUMP
sumerged pump oil is most allways a fire resistant (smokeless) type of mineral oil , when filling any pump allways allow for heat expansion !!!
May 13, 2012 | Little Giant Garden
Alittle oil leaks from this pump during operation, is this oil toxic?
no but if oil is leaking out water will be going in and that does not work well, You need to have it serviced
Thanks
Tom
Sep 08, 2011 | Little Giant Tools-Products - 5 Asp...
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
Little Giant Pump - dialectic oil to use
ck your local yellow pages for an electric motor repair shop they should be able to get silicone oil to add , but in a pinch ive used full synthhic auto transmission oil that works too
Jul 29, 2009 | Little Giant Submersible Sump Pump, 1/4 Hp
Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V Automatic Submersible Sump Pump, 8'  Power Cord  Logo
114 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
