Question about AO Smith York Draft Inducer Furnace Motor 460 Volt 9526
My connector box on my York Stellar Plus furnace P2UDD12NO7601c has a crack. This part is no longer made. WHere can I find this part?
  • Kal O Oct 26, 2012
    This is a collector box not connector box.
    Sergeant:
    Champion:
  • 426 Answers
You may have to go new
Posted on Nov 06, 2013
I have a York Stellar Plus furnace (1994 model) on which the ventor (air induction) motor will not turn off. This problem just started. The Furnace seems to work fine, but the ventor runs continuously. I'm...
The W on the board initiates the start up sequence so I believe your problem is with the relay on the control board. probably stuck closed you need to replace the board
Apr 12, 2011 | Heating & Cooling
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
Feb 20, 2010 | York Furnace Draft Inducer Blower Fasco #...
Condensation from small blower shorts out circuit board.
Put a plastic bag over the control board that will allow it to breath. you can add sealant to joint but you should clean the old off first. Then use some cork tape after sealant dries. You may also use pvc glue but it will never come out after that, but can be cut w/ saw if that becomes nessary.
Feb 01, 2009 | York Yankees Bedding MLB Comforter
Owners Manual
York Corporate Headquarters
631 South Richland Ave.
York, PA 17403
Phone: (717) 771-7890
Contacting York
Mail:
York International Corp.
P.O. Box 1592
York, PA 17405-1592
USA
Phone: (877) 874-7378
York Website
York was purchased by Johnson Controls in 2005
Johnson Website.
I cannot find an actual manual online. I hope this information helps you. Good Luck.
Dec 27, 2008 | York Yankees Bedding MLB Comforter
AO Smith York Draft Inducer Furnace Motor 460 Volt 9526 Logo
191 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
