Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma MP210 printer paper pulls to the right
I have printed about 5 times and now whenever I try to print, the paper pulls to the right. I have checked for any foreign objects, checked paper thickness and etc. but everything seems in proper order. I need a printer that works more than 5 times. This is an all-in-one model, serial #JJTE32829 purchased from Best Buy back in May 08 with my HP laptop. What a disappointment. Thanks for your help in advance. Judy B
  • 12 more comments
  • cbotsford Jan 03, 2009
    Exact same thing happens to me. Printer paper pulls to right and won't go through. Checked all possible solutions given in printer guide (i.e. paper size). I got mine in May of 08, too.
  • hienphan1010 Jan 04, 2009
    I have the same problem. Paper is pulled to the right. Purchased at bestbuy back in May 2008. Cleaned the roller and still problem presists. Did you find your solution?
  • corbettpc Jan 05, 2009
    Getting An E-3 error, paper jam but no paper in machine. Paper was pulling to the right before all this happened.
    Going to return as only bought in sept.
    Will be getting an HP this time!!
  • mreal126 Jan 06, 2009
    having the same problem, bought it a couple months back for school. Very annoying.
    Having same problem, bought a couple months back for school. very annoying
  • Patty 89 Jan 26, 2009
    Wow. I did not know so many people had the exact same problem. I bought my printer from Best Buy as well but it can with the computer. Serial JJTE33161. Has anyone fixed their problem or a new one who be better?
    Laura
  • gbradbe465 Feb 07, 2009
    Tried all of these solutions, but no luck. It is back in its box placed in the darkest spot in the basement! Replaced by an HP J4540 All-in-one trouble-free printer. Bah humbug to Cannon's.Thanks so much for all of your responses.
  • Anonymous Feb 07, 2009
    does the same thing am geting mad
  • getyourphx Feb 09, 2009
    thats exactly what happened to my printer, it was fine and now its a pulling all the way to the right.  fantastic.  ill try this card stock trick... i hope it works well
  • Anonymous Feb 20, 2009
    Running the card stock through seems to have resolved my problem. Thanks!!!
  • ajjsfaith Feb 27, 2009
    printer pull only to the right when trying to print
  • Marianne Mar 03, 2009
    Hey,
    You all are great!!!!! After about 5 times thru the card stock pushed out a twisty tie. When it finally caused it to move forward it make quite a bit of noise until I could get my fat fingers in to grab it. Heaven only knows which of my kids tossed this in!!!! Thanks a bunch!!!!! Maire
  • nao561 Mar 06, 2009
    I have exactly the same problem. I've had this printer since 03/08.
  • carlynsmommy Mar 11, 2009
    Putting a wedge of paper in the printer is not working what elese can i do
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 26, 2009
The roller is too high to engage the paper if you only have a few sheets, the solution for me was to load a big wedge of paper ....then everything was o.k.
Posted on Mar 10, 2009
Hi!!
Posted on Mar 06, 2009
My Canon MP210 is not sending paper through when trying to print. The roller doesn't seem to be able to grip the paper properly
Precisely. On many printers that get older, the rollers shrink and don't grip paper properly. I had this problem on a laserprinter made by HP, that would take 5 sheets at a time due to this problem.
Feb 12, 2011 | Canon PIXMA MP210 InkJet Printer
Canon MP210 Paper Jam
A common issue is moisture. As the relative humidity changes, the paper will absorb some of the excess moisture. (Ink jets don't get as hot as other printers; but they do have temperature changes during operation.)
Unfortunately, the only solution that I have ever found is to use paper from a just opened package. Try to keep only enough paper in the printer for a short duration of printing (1-2 weeks). Keep the rest of an open package of paper somewhere else where the temperature and humidity stays fairly constant.
I hope this helps.
Feb 26, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Printer pulls paper to the right...causes paper jam
possibly some paper is stuck in the printer. Can you manage to open the printer and check this out. If no paper at all then possibly carry it in for in-warranty service to the company outlet.
Jun 25, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 paper jam
try to get in touch with canon service centre in your area and get it fixed it will be a small problem
Feb 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam under print cartridges
Stick a 9x12 piece of cardboard down into the tray to force out unseen pieces of paper.
Jan 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error code:2,114,0
HI
I have Canon PIXMA MP210 printer but problem is that whenever i given comand for print or scan than computer show "Code: 2,114,0" this message therefor printer not print or scan. so please give me solution
Thanking you,
ayyub_thakur@hotmail.com
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
375 people viewed this question
old marine
old marine
