Question about Panasonic DP-8020E Black and White Copier
PRINTOUT HAVE SOME BLACK DOT ON PAPER
WHEN I TRY TO PRINT THE DOCUMENT, THE DOCUMENT PRINT OUT IS NOT CLEAR, THERE ARE SOME BLACK DOT AND LINE ON DOCUMENT.
  • kevshao Jan 02, 2009
    I CHANGE A NEW TONER, BUT PROBLEM IS STILL THERE,PLEASE HELP ME
  • Panasonic Master
  • 19,396 Answers
If you get black dot on the printout it is called toner specs, and this is how it looks like:
To fix this you first replace the toner, as you already did.
If that did not help then you need to clean the printer internally, see: Clean your laser printer safely with these tips
Posted on Jan 11, 2009
    Genius:
  • 1,239 Answers
The problem with this printer is that the Printhead is buried deep in the printer and is very difficult to get to. One trick that someone tried is to purchase print head cleaning solution from a website such as www.fillserv.com and fill an empty cartridge with the solution. Then constantly do head cleaning until the cartridge is empty and then try printing. You need to be good at refilling brother LC41-BK cartridge which is very difficult in the first place. I don't recommend it because it may cause more damage. When my Brother printer head got clogged I just threw it away. Its just not worth it in my opinion but at least you have an option.
To learn how to refill a brother cartridge go to this website.
http://www.refillinstructions.com/Brother/B4.htm
Thanks for reading
Hope this Helps!
Posted on Jan 02, 2009
    Genius:
  • 1,268 Answers
It's just a driver problem Initially, what you can try is Uninstall printer software and river then reinstall the driver. You can also use updated driver. Try to use a different USB cable.
    Brigadier General:
  • 5,158 Answers
Take the toner cartridge out and shake it abit.... keeping it level... then reinstall it and try it
    President:
  • 1,990 Answers
You need to Reallign the Print Cartiges. and Print a Test page . Might need a new Ink Cartridge
  • Travis Humphries
    Travis Humphries Jan 02, 2009
    Ok Exactly what kind of Printer do your have?
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
(HP laser jet 3030 all in one) Bad printout quality (wide black line in center) only when i used it as copy machine
Are you copying from the glass or the automatic document feeder? It sounds like you have something on the glass. Liquid paper is the most common culprit in messing up the glass. Use a good glass cleaner and a soft cloth to clear the glass surface.
Apr 25, 2011 | HP LaserJet 3030 All-In-One Printer
I have a 3800n that the print quality is very poor-meaning the background is gray streaks where the paper should be the only thing you see. Making the paper look dirty. hope that explains things. this...
You can try changing the print density under print quality in the control panel. YOu can also check the reset to factory default and see if this helps. It could need what is called a maintenance kit where the fuser and rollers are replaced. I install these all the time and sounds like this is what you need.
Mar 19, 2011 | HP LaserJet 3800n Printer
I have downloaded the printer drivers for my HP Deskjet D2460 from the HP site but I have no printer toolbox and therefore cannot clean cartridges etc. Can you help
Hi Kimsmith99
Please do not worry. You can try the following.
1. Simple take the cartridges out from your printer.
2. Use a clean cloth and some distilled water.
3. Clean the copper connections of the print cartridge gently with the help of the clean water and a clean cloth .
4. Take a tissue paper and then try to mark a stamp from the cartridge print head on that tissue paper.e
5. Do it till you get a clear color / black parallel line on the tissue paper.
6. Once you get a clear parallel mark on the tissue paper, insert the cartridge back in to the printer and the take 2-3 printouts.
7. You will get the clear printout for sure. This is my practical experience.
Thanks & Regards
Ashish Rohilla
Aug 21, 2010 | Office Equipment & Supplies
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
My hp officejet j5750 does not copy
hi im josh in cebu phils.try my solutions
.tt1 {font-size: 10pt;} If your printout is not as you expected, there might be several causes. The most likely cause, believe it or not, is our old friend the poorly connected cable. If all the instructions don't make it from the computer to the printer, your printout will be incomplete, if not totally out of whack. Check all cable connections to ensure a good throughput of data. If that doesn't fix the problem, just change the printer cable. An old or damaged cable could be causing your problems.
tip
tip_icon.gif Printing the printer's self-test page is also a good way to determine whether the problem is in the printer or in the computer—or somewhere in-between.
Another cause of print garbage might be the printer itself. If you have a low or old toner cartridge in a laser printer or a near-empty ink cartridge in an inkjet printer, your printout will be lighter than normal, perhaps even unreadable. If necessary, change the cartridge and run the print job again.
If you're using a laser printer, you might get black streaks on your output. This problem is most often caused by an old toner cartridge, or by a dirty roller or printer cleaning bar. If you replace the toner cartridge and clean the suspect parts (using a cotton swab) and you still experience black streaks, your printer might need service.
If you're using an inkjet printer, it's possible that your print jets are clogged. You'll need to unclog the print jet by inserting a small pin into the jet.
It's also possible that a paper misfeed in your printer caused the printout to become smudged or out of line; if this is the case, straighten the paper feed and start the print job again.
An incorrect printer setup in Windows can also cause unusual printouts. Make sure that Windows is configured for the exact type of printer you're using. Also make sure that you have the correct landscape (horizontal) or portrait (vertical) printing option selected.
If none of this works, you probably have a problem somewhere in your printer. Although a bad printer port on your PC could be the culprit, more than likely some internal problem with your printer is causing the poor printout. (You can confirm this by printing a self-test page; if it looks bad, the problem is in your printer.) Consult your friendly repair center.
Problem: Your Printed Page Looks Half-Finished If you're trying to print a document with a lot of graphics (especially on lower-priced laser printers), you might find that your printer doesn't have enough memory to print the entire document. What you'll get is about half the document—and not always a contiguous half! You can do one of several things to rectify the problem:
  • Add more memory to your printer. If you do a lot of heavy graphics printing, you probably need at least 1MB of RAM installed in your printer. You might be able to add the memory yourself, or you might want to have a qualified laser printer technician do the job for you.
  • Instruct Windows to print this document at a lower resolution. Go to the Printer Properties dialog box for your printer and select the Graphics tab (if your printer has this option). Select a lower resolution (which requires less memory and gives you less finely detailed output) and see if you can now print your document.
  • Simplify your document. If you're using a lot of different fonts and graphics, take some out. It's not an ideal solution, but it might be the only way you'll get this particular document printed on time!
Problem: Your Printer Prints, but the Fonts Aren't Correct If you create a document on a PC with one set of fonts installed, and try to print it on another PC with different fonts installed, you could be in for a real surprise! Windows will try to "match" missing fonts, but quite often the match leaves a lot to be desired—resulting in different line lengths and page breaks than what you had originally. Your options are to install the missing fonts on the PC you're printing from, or change the fonts in the document in question. (A word to the wise: stick to common fonts such as Arial and Times New Roman if you think you'll be sharing a document on multiple PCs.)
Problem: Your Color Printer Doesn't Print All Available Colors This problem is most likely caused by an old ink cartridge. It's not unusual for some colors to get depleted before others, throwing off your color output. If you're seeing less blue (or red or yellow or black) than normal, chances are it's time to change your cartridge.
Problem: Paper Jams in Your Printer It's possible that your printer's internal paper feed mechanisms are getting dirty. You can try taking the printer apart yourself to clean out any pieces of scrap paper or other debris, or you might want to take it into the shop to let a pro deal with it.
You might also be getting some paper sticking to other sheets of paper in your paper tray. (This happens more often with cheaper paper—spend a little more and get the good stuff!) Try thumbing through the stack of paper before inserting it into the tray; this should loosen up the paper and make it feed easier into your printer.
Finally, you might need to change the grade of paper you use with your laser or inkjet printer. Lightweight papers tend to jam up the works, so switch to something heavier if you experience a lot of problems.
THE ABSOLUTE MINIMUM
  • Most printer problems are caused by a bad cable connection, a misconfiguration in Windows, or a bad or outdated print driver.
  • All printers need periodic maintenance; make sure you regularly change toner or ink cartridges, clean the paper path and feed, and—if you have an inkjet printer—use the cleaning option to clean the ink jets and cartridge.
  • If you're having trouble printing graphically intense documents on a laser printer, you might need to add memory to the printer or simplify the documents.
  • Lightweight paper can cause unexpected paper jams; use a better grade of paper to keep things running smoothly.
  • good luck friend
Mar 05, 2009 | HP Officejet Pro L7480 All-in-One...
Black line on document when I scan from platen or ADF or scan to save as PDF.
As a tech I've never seen that happen. from the doc feeder only Yes, not both the feeder and the glass but not show up when you print from the computer ?????????
For sure there is a dot or something on the small strip of glass, only when you do it from the feeder.
the reason is that the document is moving and the dot on the "small" strip of glass now looks like a line to the copier.
You said it also does it when you lay it down on the glass !!??(platen) that should of indicated the drum has a ring around it, but since it doesn't come out on the PC copy then the glass must have a line on it.
Oct 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Empty ms word printout
Hi, You can try: 1. go to Start, Printer and Faxes, right click on your 3745, click on Properties, Printing Preference; 2. Check to see if you have any Advanced tab or button; 3. Check if you can set the printer to text only; 4. Check if you can set the printer to use black ink only. 5. In MS Word, verify through the use of Print Preview that your document is as you would want to be printed; 6. In some instances you may have to set manually text color in MS Word. While your document is open, click Ctrl + A to select all, then choose font color to "Black". Alternately, in your MS Word, you can click on "Format", "Font", "Font Color" set to "Black" rather than "Automatic" and set this as the "Default" setting. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | HP DeskJet 3740 InkJet Printer
Panasonic DP-8020E Black and White Copier Logo
46 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
