Question about DeLonghi PAC A120E 12000 BTU Portable Air Conditioner
Delonghi PAC a120E probe failure - wiggle and clean contacts solution doesn't work. How can I get new probes?
jfpogie
  • 104 Answers
SOURCE: DeLonghi Pinguio Pac 45
1. Clean air filer every 2 weeks.
2. clean ACCU and FCU every 3 months.
3. check and re-tight all electrical connection every 6 months.
Posted on Jan 20, 2008
  • 121 Answers
SOURCE: Probe Failure
i service the delonghi brand in tampa fl we have seen alot of probe failures. some last years some go out in 4-5 hrs of usage
Posted on Jul 11, 2008
SOURCE: delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Posted on Sep 06, 2008
  • 134 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
Posted on Feb 14, 2009
  • 66 Answers
SOURCE: DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Posted on Feb 19, 2010
Delonghi PAC a120e ,why is it leaking and also is ther a filter
Don't know if this is the type issue you are having. I had my unit leak all over the place last year and found there was ice buildup on the inside of the unit. You would have to remove the cover completely in order to check this out. Also make sure the drain is clear.
Jun 16, 2014 | DeLonghi PAC A120E 12000 BTU Portable Air...
.DeLonghi pac A110 PF error code
Probe fault? Temperature sensing probe may have loose connection or water in the tip.
Apr 17, 2012 | DeLonghi DEC 180 E Dehumidifier
Sorry I do not speak English well. C120 pac my team. PF mark on the screen and turn on all lights. not working I have to do Thanks for your time
This unit stopped working and displayed the PF code for Probe Failure. I fixed it by removing 6 screws for the panal and 4 screws for the back panal and removing the 5 screws and 1 screw holding the ground wire off the silver box with the circuit board in it then I un plugged the little plug for the 2 probes with the black wires in it and replugged it in and wiggled it several times with the unit pluged in (be carefull not to get shocked I recomend someone with electrical experiance do this for you) the plug must get corroded but this fixed my unit.
Good luck.
Sep 13, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Laptop can't power on without battery. but plugged in
Try this. With the battery removed.
  • Plug in the AC.
  • Will pressing the power button repeatedly gently wiggle the AC adapter
If it powers on briefly then your DC jack inside the computer will need to be replaced or re-soldered.
If if doesn't power on at all get or borrow a multi-meter and set it for 20+V. With the AC adapter plugged into the wall and unplugged from the PC touch one probe to the outer metal on the part that plugs into the laptop and one probe down the center of the plug. If the probe doesn't go in all the way stick a paper clip down the center (dont let it touch the outer metal) and touch the probe to that. Ignore if the voltage reading is negative or not this just means the probes are reversed and doesn't matter really if you get a reading +-1 volt from what is listed on the AC brick. If you get nothing or it is very low then the AC adapter needs to be replaced.
If the AC is fine. Then it could be the fuse on the motherboard. In that event easiest route would be to replace the motherboard (don't think you can buy the fuses)
Comment back if you need more assistance.
Sep 08, 2011 | Acer Aspire One AOD150-1920 Netbook
Pf code definition
it stands for probe failure not power failure. there are 2 temp probes in the unit and it has an issue with the plug on the circuit board
Apr 20, 2010 | DeLonghi Pinguino PACL90 Portable Air...
When turn on display reads PF and no AC???
PROBE FAILURE -check their website for the list of error codes here
http://www.delonghi.com/
It says to contact repair department.
Mar 29, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Probe Failure
Jun 19, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Help On Your Fix Please
The instruction manual says that "PF" means "Probe Failure", that the probe is damaged.  The solution in the manual says to contact the service centre.
Customer Service:  800-322-3848  US Customer Service: 888-335-6644 Canada
May 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Pac L90
p f PROBE FAILURE
(The probe is damaged) Contact Service Center. From manual.
May 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC A120E 12000 BTU Portable Air Conditioner Logo
308 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
