Question about DeLonghi PAC L90 Portable Air Conditioner
Delonghi probe failure - DeLonghi PAC L90 Portable Air Conditioner
What does the alarm symbol mean on Delonghi portable ac on pacan125hpec
The appliance has a self diagnosis system to identify a number of malfunctions. Error messages (!) are displayed on the appliance display. If (Lt) is written it means low temperature; the appliance is fitted with a frost protection device to avoid excessive formation of ice. The appliance starts up again automatically when the defrosting process is completed.If (Pf) is written it means probe failure; If this is displayed, contact your local authorized service center.If (HL) is written it mean high level; the internal tray is full and you should empty the internal safety tank, however if it pops so often, contact the service center.
Aug 21, 2016 | DeLonghi Heating & Cooling
.DeLonghi pac A110 PF error code
Probe fault? Temperature sensing probe may have loose connection or water in the tip.
Apr 17, 2012 | DeLonghi DEC 180 E Dehumidifier
I have a pf code and it wont cool
PF = Power Failure. Refer to your user manual to reset unit after a power failure.
Jun 12, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Pf code definition
it stands for probe failure not power failure. there are 2 temp probes in the unit and it has an issue with the plug on the circuit board
Apr 20, 2010 | DeLonghi Pinguino PACL90 Portable Air...
When turn on display reads PF and no AC???
PROBE FAILURE -check their website for the list of error codes here
http://www.delonghi.com/
It says to contact repair department.
Mar 29, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Error message
I have the same problem. It is caused by the thermister thermal probe going bad (open circuit). Delonghi wont sell you the probe which probably costa about $2, they want to sell you a new control panel for $93. You can replace it with another thermister and it works but it will probably be out of calibration.
Jul 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Probe Failure
i service the delonghi brand in tampa fl we have seen alot of probe failures. some last years some go out in 4-5 hrs of usage
Jun 19, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Help On Your Fix Please
The instruction manual says that "PF" means "Probe Failure", that the probe is damaged.  The solution in the manual says to contact the service centre.
Customer Service:  800-322-3848  US Customer Service: 888-335-6644 Canada
May 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Pac L90
p f PROBE FAILURE
(The probe is damaged) Contact Service Center. From manual.
May 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi PAC L90 Portable Air Conditioner Logo
41 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
