Question about Lexmark X264DNW AllInOne Laser Printer
Lexmark X264DN dirty prints how do I clean the drum?
How do I clean the drum?
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Posted on Jun 04, 2009
Printtech
  • 1087 Answers
SOURCE: lexmark x264dn windows 7 64bit.
Please download and install the scan driver from support.lexmark.com. After installing the scan driver, please check the scanner under Imaging Device from device manager. If scanner shows under imaging devices, open the scanning program and scan a document.
For further assistance, please contact Lexmark Technical Support.
Posted on Jul 14, 2011
Printtech
  • 1087 Answers
SOURCE: E120 Lexmark laser printer.
Please click on the link http://bit.ly/rkP361 to see instructions on how to go about the procedure.
For additional assistance, please contact Lexmark Technical Support.
Posted on Jul 22, 2011
My Lexmark C543DN prints with yellow streaksprinter, as you'll see...
Clean the drums on the cyan and magenta developer units with alcohol on a cotton ball. Swipe the damped cotton balls left and right and let it dry, then turn the drum about 20 degrees and repeat until you have cleaned the entire drum. Keep the units out of direct bright light and sunlight. You may also need to clean the transfer belt (black belt inside the front hatch) and rotate that to ensure clean all round. Try your print again.
Oct 28, 2017 | Lexmark Office Equipment & Supplies
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Dec 28, 2015 | Sharp Office Equipment & Supplies
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
When printing, the blue color is missing
Make sure your print cartridges have enough ink in them for printing.
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to fix the problem:
Using the Lexmark Solution Center:
  1. Click Start > Programs > Lexmark X6100 Series > Lexmark X6100 Series All-In-One Center.
  2. From the Maintenance tab, click Clean to fix horizontal streaks.
  3. Click Print. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  4. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working color cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X1190 All-In-One InkJet Printer
Not printing magenta
Print quality issues could be due to dirty or clogged print cartridge nozzles. Please follow the steps below to improve the print quality:
On the printer operator panel:
  1. Press Copy.
  2. Press Options until Maintenance appears on the display.
  3. Press the right arrow until Clean Cartridges appears on the display.
  4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  5. Print your document again to verify that your print quality has improved.
If the problem continues, try to insert a different known working cartridge or better yet replace it with a new genuine Lexmark cartridge.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x6170 not printing magenta
  1. Press Copy.
If the problem continues, try to insert a different known working cartrdidge or better yet replace it with a new genuine Lexmark cartridge.
Lexmark x264dn windows 7 64bit. Will not scan but prints just fine
Jul 13, 2011 | Lexmark X 264dn - multifunction Laser...
How do you clean the drum
Hi
Just open your drum and take the tissue and clean the drum and roll the remove the black cartridge powder to drum clean the put again... this is very simple way to clean the drum...otherwise u have to chose the HP service center also.
May 13, 2011 | HP CP3525N Color LaserJet Printer
Lexmark X264DNW AllInOne Laser Printer Logo
346 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
