Question about HP Mini 1000 Netbook
Hi my hp mini netbook turned itself off and wont turn back on. iv tried takin the battery out and put it back in. iv also tried leaving it plugged in for a while and nothing. the hp symbol comes up an
I have tried everything to try start it up
  • andrea keegan Oct 24, 2012
    its doesnt have a disk drive its only a netbook
  • HP Master
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Oct 24, 2012
tunmun
  • 413 Answers
SOURCE: hp wont turn on
Kindly check the battery and power supply as first step
Second step would be to check that ram are intactly fit in there memory module as this one of the major reason b coz of which it might be happening
As it is risky to cut open lappy as it requires professional supervision so if you rate yourself good in undrstanding electronic behaviour on board you may operate it further as i am from aplication background and if the problem persists contact the service station
Thanks and Regards
Posted on May 12, 2009
SOURCE: HP laptop wont start up properly
If it has a CD/DVD drive, and you have a 'startup disk' or similar utility disk that may have come with the system, you can put the CD in the drive, and see if it will boot from there. Normally holding down the 'F12' key will give you the menu to choose which device to boot from.
If you're not comfortable trying that type of thing, it's probably best to take it to a repair center.
Good luck, and post any updates,
Posted on Jul 27, 2009
  • 13 Answers
SOURCE: froze on hp invent screen
is there a disc in one of the drives??? Sometimes having a disc in a drive will prevent it from lo0ading,,,, if not you're gonna have to do a system recovery
Posted on Jul 30, 2009
  • 31 Answers
SOURCE: my HP Pavilon Zed 145 wont start up. Keep turning
Try to run on AC power with battery removed. If still problem persists, then its time for repairs!!
Posted on Sep 07, 2009
  • 57 Answers
SOURCE: How do I fix a HP mini netbook where I downloaded
After dealing with the folks in India, I found the following; keep pushing the F6 key as you startup your HP, it should lead you to a Roxio BackOn Track restore feature. Select restore and grab a restore date
Posted on Feb 16, 2010
Hp 110 mini will turn on and work but wont charge and the light is blinking steady red. Does that mean the battery is dead or the charging circuit is fried?
If you perform a normal charging cycle on your Netbook and it does not work afterwards, the battery may be unable to charge and will need to be replaced.
Jul 27, 2014 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
No power to my hp mini
I also have an HP and also had the same issue with a no power, go and remove the battery from the Laptop and try to connect the AC Adapter again and try to power on the Laptop if the Machine turns ON without the Battery in it then the issue can be 2 things it is either the battery is dead or the battery bay on your laptop need to be checked for repairs on the issue...
and the only people to got to best would be HP, also if you can try a known good battery that works and connect it to your Laptop to check if it will turn ON that may also work and if the Laptop does turn ON using a known good Battery then the issue is just the battery and nothing related to the battery bay on the lsptop, which makes thing easier since a new battery is easier to buy than having your laptop sent back to the manufacturer for repairs.
I hope that the issue is just the Battery.
Try a known good battery first before having someone open your Laptop :)
have a Good Day .
Oct 22, 2012 | HP Mini 1000 Netbook
Battery wont charge
Please check the battery charger. Otherwise, I had one of this HP Mini 1000 replaced by HP with the same problem, the Mini gone complete dead, no charging or turn on.
Apr 07, 2012 | HP Mini 1000 Netbook
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
Dec 04, 2011 | MSI Wind U120-020US Netbook
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
My HP mini 1000 screen will not turn on.
Welcome to fixya.Try to do a hard reset on the computer,unplug the cable,remove the battery then without any power sources hold the power button for 30 seconds.After doing the step,put the battery in and plug the computer's ac adapter and turn on the computer normally. If this did'nt work,try using an external monitor and check if it will work or not.If it worked then that means there is something wrong on the monitor of the computer and if it did not then most likely there is an issue on the motherboard or the video card of the computer and in that case you have to contact the manufacturer of the computer.
hope this helps..:)
Sep 11, 2011 | HP Mini 1000 Netbook
Mini hp 110, Im not at home, need my computer. won<t boot, F11, F8, hardboot wont work... what can i do! I have 3 years of pictures on it... find me a efficient solution RIGHT NOW! :(
First try Hard Reset:
1. unplug ac adapter then remove the battery.
2. press and hold the power button for a minute.
3. put the battery back, plug in ac adapter.
4. turn on the mini .
if it does not work, see if light glows on the power jack.
then remove and reinstall the hard drive.
see if it works .
Jul 14, 2011 | HP Mini 1000 Netbook
HP mini wont turn on and power led blinking
Removed the battery - power it up from your a/c adapter then refit the battery -
Jun 26, 2010 | HP Computers & Internet
My TOSHIBA MINI NB205-n313/9 10.1 inch net book will not turn on
The laptop is not turning on?
Remove the battery and try boot the machine on AC power only. If the computer starts up turn it back off, reinsert the battery and try to boot the computer again.
If it still won't boot with the battery inserted then i suggest you send or take the computer back as there is a hardware problem.
Regards.
Sep 15, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Hp mini wont start
i had a similar problem. this made my netbook start again. turn off your netbook and then remove the battery. then (with the battery still out) slide the power switch into the on-position and hold it there for a minute. then reinsert the battery and turn on your netbook. as soon as it turns on, keep repeatedly pressing the F10 key till you see your screen light up. then login normally and go to the hp site and download the driver for your netbook. i think its under BIOS? hope this helped. sorry if it didnt...
Apr 08, 2009 | HP Mini 1000 Netbook
HP Mini 1000 Netbook Logo
85 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
