Question about Sewing Machines
Presser foot will not go up or down
The presser foot lever and the knee lift lever will not allow the presser foot to go up or down. My Janome MC9000 is 17 years old
  • Sewing Machines Master
  • 1,564 Answers
Broken. Send it in.
Posted on Nov 06, 2012
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
SewTechWayne
  • 186 Answers
SOURCE: MC 11000 janome stops reading presser foot "p"
This is a relatively easy adjustment as I just did one last week but I'm not sure I can explain it. Anyway, open up the lamp cover and look at the top of the presser bar. There is a sensor that is easily adjusted. It has a small phillips screw that you need to loosen. Then move the black 'L' shaped piece either up or down a little (I can't remember which way) and re-tighten the screw, you may need to experiment. The 'L' shaped piece is a flag that goes between two sensors when the foot is raised and can be rotated left and right about 10 degrees. I hope that helps.
Posted on Feb 08, 2009
Sewtech1
  • 69 Answers
SOURCE: presser foot won't go all the way down
need a bit of oil on the take-up lever shaft and just work it in
Posted on Jun 28, 2009
Zenqi
  • 208 Answers
SOURCE: the presser foot lever seems to have lost tension.
What is the brand and model of your machine?
Posted on Jan 05, 2010
isaiahpro
  • 35 Answers
SOURCE: Elna serger 925 presser foot lift lever broke off.
Purchased an Elna Pro 925 DCX and it was missing the sewing cover to do sewing without using the blades. This is a plastic cover piece that snaps on to the machine when coverstiching. Where can I fing this part?
Posted on Aug 19, 2010
Janome 5124 pressure foot to keeps falling off.
Sounds like the presser foot holder is bad, get a new one.
May 25, 2017 | Janome Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
When i release the leg lever to let down the presser foot ,the foot wont release all the way and now it wont stitch
Mine does this too sometimes. Lift up the head and look in the middle of the oil pan. The knee controller runs through there. Make sure the black knob is not stuck. Hit the knee thing a couple of times to make sure it is not stuck. It should move freely up and down. That may fix the problem. If not, look st the small post to the left and behind the oil intake. Move the manual presserfoot lever on the machine to see it move. It will be stiff, but it should still lift a little. Usually jigging these two parts will fix the problem. Good luck..
Mar 22, 2016 | Juki DDL-5550 Industrial Straight Stitch...
Why doesn't walking mechanism work?
if the pressor foot anvil doesn't move up and down /back/forth , the machine might be in "DARNING " mode this is usually a small button in the bobbin area , but some machines have them on the back of cabinet as well
Feb 26, 2016 | Sewing Machines
How do I fix the following problem with my Janome MC9000 sewing machine?
Unfortunately you are probably not going to be able to fix this.
It needs a sensor adjusted (probably), or a component replaced.
Sep 25, 2014 | Janome Memory Craft 9000 Computerized...
Pressure foot will not lift up
do u have an automatic machine meaning ft is lifted by pressing ft pedal a certain dirtection. otherwise tilt machine and push knee lever. there should be a flat oval piece on top of lever rod. does it rise straight? it needs to contact the push rod on the machine presser ft. see if the line up by lowering the machine slightly. if not bend rod to aglin. your knee lift may need adjustment too and maybe the presser ft screw located by removing the rubber plug on side of machine or take off the plate by removing 3 screws. careful with gasket cause machine will leak if u tear gasket.. presser ft screw is easy to find. lower ft and tighten. make sure that the needle is centered in foot slot when adjusting presser ft screw. otherwise thread will break when needle hits side of presser ft. a very common problem that many do know about and someday i will charge the site. 35 years with juki and still going strong.
Apr 22, 2014 | Juki DDL-8700
Pressure foot won't stay up
The presser foot lift lever on many newer janome sewing machines will wear out with use. It can easily be replaced by a sewing machine repair shop or Janome dealer. Or you can look online for a "presser foot lifter" or "presser foot lift lever" making sure to find the correct one for your machine.
Mar 03, 2014 | Janome Sewing Machines
The presser foot on my Janome MC9000 will not go up or down
yeah the cam lever is probably broken. Time for a new machine???
Oct 24, 2012 | Sewing Machines
Presser foot lever won't lower the foot
This may be a lubrication problem on the presser foot shaft. Try freeing up with penetrating oil or Triflow. After letting set for an hour lower the presser foot and pull down on the ankle. If that does not work you need to open the machine and loosen the clamp screw on the presser foot shaft. Then try to twist the shaft to loosen it up.
Nov 21, 2017 | Janome Sewing Machines
Sewing Machines Logo
339 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
