Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Clean water leaking - Bissell SpotBot Robotic Wet/Dry Vacuum
  • Bissell Master
  • 18,391 Answers
Check for cracks and all rubber seals
http://www.vacsite.com/en/bissell-/002V-2036643.html
Posted on Oct 24, 2012
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
Trigger pin is stuck or something else is wrong. why is it constantly leaking water as soon as I plug it in?
You will need to provide more information as in the model AquaMate you are using as I can't determine which one by your information. You can also call and speak with a tech. at 800-640-2033.
Rainbow Vacuum Cleaner Systems Repair Center
Mar 28, 2014 | Rainbow E series Canister Wet/Dry Vacuum
D4 Rainbow leaking water around the water basin while running. Already replaced the seal. Still leaking.
Clean the water separator. Use a tooth brush if you do not have the Rainbow separator cleaning brush. It is the same thing, and works perfectly. :-)
Ralph
Dec 20, 2010 | Rainbow Technologies D4 Bagless Vacuum
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Clean water tank leaks
Your going to have to replace it again, good thing is they completely remodeled the new one.
Aug 26, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac clean water reservoir leaking.
take the clean water tank out and look on the bottom for a fitting that screws on make sure its tight.also inside of that fitting trhere should be a washer or an oring to keep it from leaking.if thats not the problem then your pump mightbe leaking.for that i would take it to a vacuum repairman.i hope i have been of some help.please leave feedback
Apr 07, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Clean Water Tank Leaks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=612034
Posted by Liviaa on May 21, 2008
The clean water tanks leaks. What's causing the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . It looks like the one of the holding or recovery tanks my not be in place, leaking, cracked or damaged, or the clear tube is leaking and needs replacing. I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 21, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
Oct 20, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
