Question about Refrigerators
Samsung rb215labp: freezer is making loud noise and not staying cold
hiltonjug
  • 612 Answers
SOURCE: Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Posted on Nov 12, 2009
Testimonial: "I turned off the freezer side and it defrost for a few hours. Then I turned it back on and its working fine for 2 days now. "
HVACRH20
  • 237 Answers
SOURCE: My fridge makes loud popping noises
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Posted on Dec 23, 2006
  • 1314 Answers
SOURCE: Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
Posted on May 14, 2008
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
  • 15 Answers
SOURCE: My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
Posted on May 26, 2009
Owner Manual available on line?
SAMSUNG REFRIGERATOR USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > Refrigerator
View and Download Samsung Refrigerator user manual online. ... Removing the Front Leg Cover First, open both the freezer and refrigerator doors, and then ...
SAMSUNG RB215LABP OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RB215LABP
Refrigerator Samsung RB215BSSW Owner's Manual ... REFRIGERATORRB215LASH, RB215LABP OWNER'S MANUAL In the U.S. for questions about features, ... When you open the door, an item may fall out and cause personal injury or ...
Jan 12, 2016 | Samsung Refrigerators
Cant Get fridge and freezer to cool to correct temp
According to the picture posted the freezer defrost is stuck on. Why it would not get cold enough. Contact a local appliance repairman and get professional help as this should require control board repair/replace.
Jan 02, 2014 | Refrigerators
Refrig will not get cold freezer is fine, fan was sounding very loud last week but it stopped making the loud noise n the refrig seemed fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 25, 2011 | Samsung RF265AA Bottom Freezer French Door...
My samsung rs21dgrs is making very loud noise
Sounds like your Samsung RS21 has devoloped a known fault.
Your frdige will be cold in the drawers but not cold above this? Also there is ice around the pipe behind the drawers. it is the ice hitting the fan that is the noise and eventually stops the fan which pushes the cold air around the frdige.Samsung have extended their warranty to 5 years to cover for this.
You need to call the Samsung customer care team 0845 7267864 and should be repaired free of charge. - mine was. When you call, you need the full model number and serial number. my serial number was on the outside left hand side of the fridge. The engineer comes out within a day or 2.
Jun 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cake Display Freezer Compressor keeps freezer cold
Maybe the guy meant the compressor is going bad.
Jul 24, 2017 | Traulsen Reach in Freezer - G12010
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
